Paralellization of compiled DPM UDF
Old   April 23, 2019, 07:23
Default Paralellization of compiled DPM UDF
Sebi
bloodflow is on a distinguished road
I am trying to find the distance between a particle and the wall using a Compiled UDF and DPM_OUTPUT. To do this I want to use the C_WALL_DISTANCE(c,t) macro, but I am struggling to use it in parallel mode. I figure I should take the cell a particle is in using P_CELL(p), and then calculate the wall distance from there. The UDF compiles and loads without errors, but then you "start" the trajectory sampling you get SIGSEGV errors and figure it must require some extra constraints. My UDF is below if anyone has experience with the C_WALL_DISTANCE(c,t) macro please help.
DEFINE_DPM_OUTPUT(particledata,header,fp,p,t,plane )
cell_t c=P_CELL(p);
if(header)
par_fprintf_head(fp,"Particle-ID X-Position Y-Position Z-Position X-Velocity Y-Velocity Z-Velocity Time Wall_Dist\n ");
if(NULLP(p))
return;
par_fprintf(fp,"%d %" int64_fmt " %d %e %e %e %e %e %e %e %e \n",
P_INJ_ID(P_INJECTION(p)),
p->part_id,
p->part_id,P_POS(p)[0],P_POS(p)[1],P_POS(p)[2],P_VEL(p)[0],P_VEL(p)[1],P_VEL(p)[2],P_TIME(p),C_WALL_DIST(c,t));
bloodflow is offline   Reply With Quote
Old   April 23, 2019, 22:30
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
if you are going to use C_WALL_DISTANCE(c,t) where is it?
for your code try this:
#if !RP_NODE
cell_t c=P_CELL(p);
if(header)
if(NULLP(p))
return;
p->part_id,
#endif
read Chapter 7: Parallel Considerations
in Ansys Fluent Customization Manual
AlexanderZ is offline   Reply With Quote
Old   April 24, 2019, 04:43
Sebi
#if !RP_NODE
cell_t c=P_CELL(p);
if(header)
if(NULLP(p))
return;
p->part_id,
#endif
I am looking through that chapter but cannot work out which part of my code should be done on which node. The Wall distance macro is the last thing to be called in the "P->" string.
Using the command you suggest causes the error before you start the calculation, when you "start" the sampling.
Node 999999: Process 29151: Received signal SIGSEGV.
MPI Application rank 9 exited before MPI_Finalize() with status 2
The fluent process could not be started."
So I'm just not sure how to use this in paralell.
Old   April 25, 2019, 03:29
Alexander
try
C_WALL_DIST(F_C0(f,t),THREAD_T0(t))
best regrards
Old   April 25, 2019, 07:31
Sebi
try
best regrards
Do I need to define any additional things? Like "f"?
Old   April 26, 2019, 00:34
Alexander
my bad,
yes
try
 f = P_FILM_FACE(p);
best regards
Old   April 26, 2019, 04:55
Sebi
Thank you for your help but the UDF is still not able to compile. The code below:
DEFINE_DPM_OUTPUT(sampleparticles,header,fp,p,t,plane)
real f;
real distance;
f=P_FILM_FACE(p);
cell_t c=P_CELL(p);
distance=(C_WALL_DIST(F_C0(f,t),THREAD_T0(t)));
if(header)
 par_fprintf_head(fp,"Particle-ID X-Position Y-Position Z-Position X-Velocity Y-Velocity Z-Velocity Time Wall Dist \n ");
if(NULLP(p))
 return;
 p->part_id,
 p->part_id,P_POS(p)[0],P_POS(p)[1],P_POS(p)[2],P_VEL(p)[0],P_VEL(p)[1],P_VEL(p)[2],P_TIME(p),distance);
#if REMOVE_PARTICLES
 MARK_PARTICLE(p, P_FL_REMOVED);
#endif
Gives the following error below:
in file included from /rds/bear-apps/handbuilt/software/ansys_inc/v181/fluent/fluent18.1.0/src/udf/udf.h:24:0,
                 from dpm.c:3:
dpm.c: In function sampleparticles:
/rds/bear-apps/handbuilt/software/ansys_inc/v181/fluent/fluent18.1.0/src/storage/mem.h:1002:52: error: array subscript is not an integer
 #define F_STORAGE(f,t,sv,type)(T_STORAGE(t,sv,type)[f])
/rds/bear-apps/handbuilt/software/ansys_inc/v181/fluent/fluent18.1.0/src/storage/mem.h:1105:54: note: in definition of macro C_STORAGE_R
 #define C_STORAGE_R(c,t,n)(T_STORAGE_R_NO_CHECK(t,n)[c])
dpm.c:14:11: note: in expansion of macro C_WALL_DIST
/rds/bear-apps/handbuilt/software/ansys_inc/v181/fluent/fluent18.1.0/src/storage/mem.h:2151:18: note: in expansion of macro F_STORAGE
 #define F_C0(f,t)F_STORAGE(f,t,SV_C0,cell_t *)
dpm.c:14:23: note: in expansion of macro F_C0
dpm.c:13:8: warning: unused variable c [-Wunused-variable]
 cell_t c=P_CELL(p);
dpm.c:10:6: warning: variable f set but not used [-Wunused-but-set-variable]
 real f;
Old   April 29, 2019, 01:17
Alexander
f is a face and should be defined as:
face_t f;
seems you dont know the basis,
try to find information related to your problem in Ansys Fluent Customization manual first
best regards
dpm, sigsegv, udf
UDF for deleting particles in DPM imanmirzaii Fluent UDF and Scheme Programming 12 November 25, 2020 19:27
Viscosity UDF works when interpreted, Doesn't when compiled? bloodflow Fluent UDF and Scheme Programming 4 April 11, 2019 09:06
UDF compiled and loaded but not available Easyeight Fluent UDF and Scheme Programming 7 June 28, 2018 11:54
Conditional Release of DPM Particles in Fluent - UDF nvschandra Fluent UDF and Scheme Programming 0 December 16, 2013 20:32
Conditional Release of DPM particles - UDF nvschandra Fluent UDF and Scheme Programming 0 December 10, 2013 11:02
