Defining two different heat transfer coefficients for porous media model
Old   April 30, 2019, 14:36
Default Defining two different heat transfer coefficients for porous media model
Justin
student_1994 is on a distinguished road
I am trying to have two different zones with the built-in porous media model. Each zone will have a different heat transfer coefficient. Currently, I am interpreting the UDF, where I have two h_sf values (h_sf_5PPI and h_sf_30PPI). Then I take the two porous zones and select one for each. But I think the code is overwriting it so that all of the porous zones are getting the second heat transfer coefficient function.
Does anyone have advice on how to change this UDF so that the first heat transfer coefficient function isn't overwritten? I am sure that the UDF is not working since the two temperatures are almost exactly the same.
#include "udf.h"
DEFINE_PROFILE(h_sf_5PPI, t, i)
cell_t c;
real vel;
begin_c_loop(c, t)
vel = ND_MAG(C_U(c, t), C_V(c, t), C_W(c, t));
F_PROFILE(c, t, i) = 40000 * pow(vel, .6352);
/*43893 * pow(vel, .6352);*/
end_c_loop(c, t)
DEFINE_PROFILE(h_sf_30PPI, t, i)
cell_t c;
real vel;
begin_c_loop(c, t)
F_PROFILE(c, t, i) = 150000 * pow(vel, .6352); /*70319 * pow(vel, .6588);*/
end_c_loop(c, t)
student_1994 is offline   Reply With Quote
Old   May 2, 2019, 00:25
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
After interpreting the UDF you will have 2 functions
hook first one to zone 1 and second to another zone.
The function should not overwrite another one.
best regards
AlexanderZ is offline   Reply With Quote
Which radiation model for heat transfer through solid? flo777 FLUENT 0 January 30, 2015 22:49
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
