Reflect Condition dpm
Old   May 11, 2019, 21:20
Default Reflect Condition dpm
FlavioC is on a distinguished road
Hello to everyone. I am studying the reflect condition for inert particles, I use the code that appears in the udf fluent manual
DEFINE_DPM_BC(bc_reflect,p,t,f,f_normal,dim)
   real alpha;
   /* angle of particle path with face normal */
   real vn=0.;
   real nor_coeff = 1.;
   real tan_coeff = 0.3;
   real normal[3];
   int i, idim = dim;
   real NV_VEC(x);
   #if RP_2D
   /* dim is always 2 in 2D compilation. Need special treatment for 2d axisymmetric and swirl flows */
   if (rp_axi_swirl)
      real R = sqrt(p->state.pos[1]*p->state.pos[1] + p->state.pos[2]*p->state.pos[2]);
      if (R > 1.e-20)
         idim = 3;
         normal[0] = f_normal[0];
         normal[1] = (f_normal[1]*p->state.pos[1])/R;
         normal[2] = (f_normal[1]*p->state.pos[2])/R;
      else
         for (i=0; i<idim; i++)
         normal[i] = f_normal[i];
   else
   #endif
   if(p->type==DPM_TYPE_INERT)
      alpha = M_PI/2. - acos(MAX(-1.,MIN(1.,NV_DOT(normal,p->state.V)/ MAX(NV_MAG(p->state.V),DPM_SMALL))));
      if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL))
      F_CENTROID(x,f,t);
      /* calculate the normal component, rescale its magnitude by the coefficient of restitution and subtract the change */
      /* Compute normal velocity. */
      for(i=0; i<idim; i++)
      vn += p->state.V[i]*normal[i];
      /* Subtract off normal velocity. */
      p->state.V[i] -= vn*normal[i];
      /* Apply tangential coefficient of restitution. */
      p->state.V[i] *= tan_coeff;
      /* Add reflected normal velocity. */
      p->state.V[i] -= nor_coeff*vn*normal[i];
      /* Store new velocity in state0 of particle */
      p->state0.V[i] = p->state.V[i];
      return PATH_ACTIVE;
   return PATH_ABORT;
But I change the tangent coefficient value setting it to one since the collision should be elastic. Then, I compare the particles trajectories using the UDF and the boundary condition type :reflect. The trajectories are so different. Can someone please explain it to me?
FlavioC is offline   Reply With Quote
condition, dpm, reflect, udf reflect
Force DPM boundary conditions on a sliding interface zone? juliahartig FLUENT 0 May 31, 2018 17:43
Symmetry boundary condition + DPM sfn Fluent Multiphase 1 May 31, 2018 17:16
updating boundary condition after one iteration and permanently babakflame OpenFOAM Programming & Development 2 June 22, 2017 22:15
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 04:13
