No response whatever from this udf
Old   May 18, 2019, 03:14
Default No response whatever from this udf
Saurabh Das
Sorabh is on a distinguished road
I was trying to include the following source term in udf:
This is the code snippet:
DEFINE_SOURCE(perfusion,c,t,dS,eqn)
	real physical_dt,temp_old,temp_now,T_derivative,source;
	physical_dt = RP_Get_Real("physical-time-step");
	if (physical_dt > 0.1)
		temp_old= C_T_M1(c,t);
		temp_now=C_T(c,t);
		T_derivative=(temp_now-temp_old)/physical_dt;
	source = -tq*rho_b*wb*cb*T_derivative;
	dS[eqn]=0;
	return source;
However I am not getting any change in my results. What am I doing wrong?
Thanks..
Sorabh is offline   Reply With Quote
Old   May 19, 2019, 22:54
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
most likely problem comes from line
from manual
Note that data from C_T_M1 is available only if user-defined scalars are defined. It can also
be used with adaptive time stepping.
check waht you get here temp_old= C_T_M1(c,t);
best regards
AlexanderZ is offline   Reply With Quote
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 12:43
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
