sinusoidal rotation UDF
Like Tree2Likes
  • 1 Post By AlexanderZ
  • 1 Post By denis Kim
Old   June 17, 2019, 08:56
Default sinusoidal rotation UDF
Ki Jong Kim
denis Kim is on a distinguished road
now i am trying to simulate the sinusoidal rotation of the cylindrical tank with below conditions.
-Amplitude: 50deg (0.872 rad)
-frequency: 0.125 hz (=period: 8sec)
The tank will be simulating with Y axis and there is no transitional movements.
The code what i did is,
#include "udf.h"
DEFINE_ZONE_MOTION(rotation,omega,axis,origin,velo city,time,dtime)
*omega[0] = 0.0;
*omega[1] = 2*3.141592*0.125*0.872*cos(2*3.141592*0.125*time);
*omega[2] = 0.0;
N3V_D (velocity,=,0.0,0.0,0.0);
N3V_D (omega,=,0.0,1.0,0.0);
return;
but i returns error message like below,
..\..\src\rotation_test_17.c(5) : error C2100: illegal indirection
..\..\src\rotation_test_17.c(6) : error C2100: illegal indirection
..\..\src\rotation_test_17.c(7) : error C2100: illegal indirection
Anyone who can help me modify the code or any comments?
(Please help me...)
It would be very help and thank you so much in advance.
Best regards,
Denis
denis Kim is offline   Reply With Quote
Old   June 18, 2019, 01:19
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
omega is a scalar,
you have to define origin and axis
Ansys Fluent Customization manual -> DEFINE_ZONE_MOTION
best regards
vavnoon likes this.
AlexanderZ is offline   Reply With Quote
Old   June 18, 2019, 06:01
Ki Jong Kim
Thank you for your valuable comments.
i am recoding in consideration of your comments.
can you give me a comments below UDF?
#include "udf.h"
*omega = 2*3.141592*0.125*0.872*cos(2*3.141592*0.125*time);
N3V_S(origin,=,0.0); /* default values, line could be omitted */
N3V_D(axis,=,0.0,1.0,0.0); /* default values, line could be omitted */
return;
Thank you in advance.
Best regards,
Kim
vavnoon likes this.
Old   June 19, 2019, 00:08
Alexander
very good code,
try it
best regards
Old   June 19, 2019, 00:13
Smile
Ki Jong Kim
very thanks@@!
It works!!
Best wishes,
Denis
Old   May 19, 2020, 13:10
Default problem in my DEFINE_ZONE_MOTION UDF
mohammad
movaffagh is on a distinguished road
hi i have a problem with my code in mesh motion rotation.i have a fuel assembly and i should simulate heaving and rolling motions. my code its in below:
#include<udf.h>
#define period 6
#define angular_freq 2*M_PI*period
#define tetamax 10*M_PI/180
DEFINE_ZONE_MOTION(fmotion,omega,axis,origin,veloc ity,time,dtime)
*omega =tetamax*sin(angular_freq*time);
N3V_D(axis,=,1.0,0.0,0.0);
return;
i need my geometry rotate between -10 and 10 degree but with this code my geo rotate between 0 and 10 degre
what's my problem?
thank's
movaffagh is offline   Reply With Quote
Old   May 19, 2020, 15:25
Default Angular Frequency
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
That's because the angular frequency is wrong. Divide it by 180.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 20, 2020, 18:03
mohammad
dear vinerm:why i should divide? i have pi in my angular frequency and its in radian unit. whats unit i should use?
Old   May 21, 2020, 07:49
vinerm's Avatar
Vinerm
You are right. You don't really need that and it actually changes nothing except reducing the rotational speed. But if 6 is really the time period then your equation for angular frequency is wrong. It should be 2\pi/6. And with that, you get one complete cycle within 6 seconds, including -0.1745 as minimum value, which corresponds to -10 in degree.
Regards,
Vinerm
Old   May 22, 2020, 17:39
mohammad
thank you for your help.
UDF Rotation lepetitmort Fluent UDF and Scheme Programming 38 October 15, 2020 06:29
udf for blade rotation mamad7192 Fluent UDF and Scheme Programming 1 May 28, 2017 17:09
UDF for non sinusoidal or varying amplitude motion with respect to time lalit kumar FLUENT 1 November 13, 2010 16:58
Sinusoidal motion udf urmazda Fluent UDF and Scheme Programming 6 July 30, 2010 11:44
VOF UDF FOR PATCHING SINUSOIDAL FREE SURFACE beginner FLUENT 1 September 10, 2007 02:16
