UDF for condensation or boiling
Old   May 2, 2005, 17:45
Default UDF for condensation or boiling
Yvonne
Hello everyone,
I am doing a project about condensation in FLUENT. There is a water-vapor two phase flow passing through a cooler wall. I am searching a UDF for condensation. Does anyone have the UDF code for condensation or boiling? Thanks in advance.
Yvonne
Old   May 4, 2005, 12:42
Default Re: UDF for condensation or boiling
edi ghirardi
I think I saw one about mass transfer in multiphase flows based on saturation temperature on the UDF manual. DEFINE_MASS_TRANSFER, or something like that.
Old   May 5, 2005, 21:51
Yvonne
hello edi ghirardi,
I already got them. thank you reply.
Best Yvonne
Old   September 30, 2010, 15:55
Default Condensation UDF
Yaamunan Venkatesan
yaamunan is on a distinguished road
Hi Yvonne,
I was searching for a condensation UDF. I am working on condensation through microchannels. I need to give water vapor at the inlet. I was wondering if i need to use udf...Since it is condensation, as the fluid flows through the channel, there should be a phase change. I was wondering if i shud give the option of multiphase in fluent. Please help me on this. I would also appreciate if you could send me ur udf file.
Best Regards
Yaamunan
yaamunan is offline   Reply With Quote
Old   October 6, 2010, 11:44
sreenivasa rao gubba
sreerao is on a distinguished road
Hi Guys
I have one developed part of my work. It is working nicely. However, you may need to change according to your problem.
DEFINE_DPM_LAW(Boiling_sree, p, ci)
double cp_gas, vap_rate_const, latent_heat;
double temp_diff,term,dia_ratio;
double fv = DPM_VOLATILE_FRACTION(p);
double diam_dry = 0;
cphase_state_t *c = &(p->cphase);
double qrad = 0.0;
Material *m = p->injection->material;
double min_liquid_mass = P_INIT_MASS(p)*(1.0 - DPM_VOLATILE_FRACTION(p));
double liq_mass = PI*(pow(P_INIT_DIAM(p),3)/6.0)*(1.0 - P_INIT_LF(p))*MATERIAL_PROP(p->injection->material,PROP_rho);
law = 3;
vapor_on = FALSE;
boil_on = TRUE;
/* Message (" ****Control is in Boiling: %16.8g, liquid mass:%16.8g, law: %i\n",liq_mass,min_liquid_mass,law); */
if (P_MASS(p) <= liq_mass)
if (ci) AddSources(p);
p->current_law_index++;
HeatMassUpdate(p,ci);
vapor_on = FALSE;
return;
if (DPM_WET_COMBUSTION(p))
m = p->injection->evaporating_material;
diam_dry = P_INIT_DIAM(p) * pow(1.-P_INIT_LF(p),1./3.);
else
if (fv < 1.)
diam_dry = P_INIT_DIAM(p) * pow(1.-fv,1./3.);
/* Message (" ****diam dry: %16.8g, org dia:%16.8g\n",diam_dry,P_DIAM(p)); */
latent_heat = MAX(1.e-20,MATERIAL_PROP(m,PROP_latent_heat));
if (ABS(latent_heat) < 1.e-20)
latent_heat = 1.e-20;
cp_gas = c->sHeat;
/*Message (" ****Cp gas: %16.8g\n",cp_gas); */
if (cp_gas < DPM_SMALL) cp_gas = DPM_SMALL;
temp_diff = c->temp-P_T(p);
if (temp_diff < 0.) temp_diff = 0.;
/* Message (" ****temp_diff: %16.8g, c->temp:%16.8g\n",temp_diff,c->temp); */
if (dpm_par.radiation_p)
qrad = DPM_EMISSIVITY(p,P_MATERIAL(p))*(.25*c->G - SIGMA_SBC*pow(P_T(p),4.));
/*Message (" ****q_rad_default: %16.8g, q_rad: %16.8g, time_step: %16.8fl \n",qrad, qrad1,p->time_step); */
if (qrad < 1.e-9)
/*Message("it is true\n");*/
vap_rate_const = 8. * c->tCond / (P_RHO(p)*cp_gas)* log(1. + cp_gas*temp_diff/latent_heat);
term = P_DIAM(p)*P_DIAM(p) - vap_rate_const*(1. + 0.23*sqrt(p->Re)) * p->time_step;
P_DIAM(p) = (term > 0.) ? sqrt(term) : diam_dry;
else
/*Message("it is false\n");*/
real ku = 2.0 + 0.46*sqrt(p->Re);
real alpha = 2.*qrad/(P_RHO(p)*latent_heat);
vap_rate_const = c->tCond * temp_diff * ku;
term = P_DIAM(p) - (vap_rate_const + qrad*P_DIAM(p))*alpha*p->time_step / MAX(qrad*P_DIAM(p),DPM_SMALL);
P_DIAM(p) = (term > 0.) ? term : diam_dry;
/*Message("term: %16.8g, diam: %16.8g\n", term, P_DIAM(p));*/
P_DIAM(p) = MAX(P_DIAM(p), diam_dry);
P_LF(p) = MAX(0., 1.0 - diam_dry*diam_dry*diam_dry /(P_DIAM(p)*P_DIAM(p)*P_DIAM(p)));
P_RHO(p) = P_LF(p) * MATERIAL_PROP(p->injection->evaporating_material,PROP_rho) +
(1.-P_LF(p)) * MATERIAL_PROP(p->injection->material,PROP_rho);
P_MASS(p) = P_RHO(p) * PI * P_DIAM(p)*P_DIAM(p)*P_DIAM(p) / 6.;
else
dia_ratio = P_DIAM(p)/P_INIT_DIAM(p);
P_MASS(p) = P_INIT_MASS(p) * dia_ratio*dia_ratio*dia_ratio;
/*Message (" P_Mass:%16.8g, Liquid_fraction:%16.8g \n",P_MASS(p),P_LF(p));*/
Hope this helps
sree
sreerao is offline   Reply With Quote
Old   July 18, 2011, 11:24
Niki is on a distinguished road
Hello sreerao!
I have recently started to work with UDF and can not understand what this line means :
if (ci) AddSources(p); //what exactly does that mean??
HeatMassUpdate(p,ci); // and that too???
vapor_on = FALSE;
return;
Thanks in advance.
Niki is offline   Reply With Quote
Old   October 15, 2011, 07:41
Yaser
unknow is on a distinguished road
hi everybody.
i have done some work on the condensation of water wapor in a condensor with Fluent.
i'm not sure about what i do.
is there anybody that can help me, please?
unknow is offline   Reply With Quote
Old   September 13, 2012, 07:43
Default request for udf for condensation
Amit
Amit is on a distinguished road
where is available udf for condensation in manual???? or can specify any other resourse??
Amit is offline   Reply With Quote
Old   April 21, 2014, 13:23
Default Wall condensation
Mahesh
Dinesh Yadav is on a distinguished road
I have to model the wall condensation for water vapor. I am new to UDF writing. If you could mail me the UDF, it will a great help to start with.
Thanks.
Originally Posted by Yvonne
;120321
Hello everyone,
Yvonne
Dinesh Yadav is offline   Reply With Quote
Old   April 20, 2016, 06:50
Wang Jie
qhwj1990 is on a distinguished road
;120428
hello edi ghirardi,
Best Yvonne
hello,Best Yvonne , I need the UDFs,too. could you give me?If not, could you tell where I can find it. Thank you.
qhwj1990 is offline   Reply With Quote
Old   April 28, 2016, 08:50
Paritosh Vasava
vasava will become famous soon enough
Have a look at tutorial titled Heat and Mass Transfer with the Mixture Model
and Evaporation-Condensation Model
. It demonstrates usage of evaporation-condensation model. I dont think you need UDF unless something very complex is happening in your model.
vasava is offline   Reply With Quote
Old   May 5, 2017, 08:40
Default Wall Condensation
  #12
Diksha
Diksha is on a distinguished road
I have to model condensation of water vapour in a vertical minichannel. I am new to fluent. Could anyone help me with it please?
I am using the evaporation/condensation model. However, I am not having the condensate film on the wall..
Thank you
Diksha is offline   Reply With Quote
Old   June 24, 2019, 16:57
  #13
Soumitra Vadnerkar
soumitra2102 is on a distinguished road
Originally Posted by Diksha View Post
Thank you
Did you solve the problem?
I used standard evaporation-condensation model, but it did not give me any significant condensation. I played with the condensation frequency as well. It did not work.
Do you have any UDF to achieve the condensation?
soumitra2102 is offline   Reply With Quote
UDF for Subcooled Nucleate Boiling Jake Fluent UDF and Scheme Programming 3 December 30, 2019 05:10
boiling and condensation udf brusly FLUENT 0 January 8, 2007 22:33
udf for boiling and condensation brusly FLUENT 0 November 22, 2006 22:17
udf for boiling and condensation brusly FLUENT 0 November 20, 2006 01:10
-What udf macro for boiling - thomas FLUENT 6 January 19, 2004 07:31
