June 28, 2019, 04:45 |
Discrete Ordinates Method UDF Macros
Krishna Prasad. G
I'm currently working on the effects of radiation in working solid rocket motor performance. I'm using the Discrete Ordinates Method for radiation modelling in Fluent. I have UDF which calculates the fuel and products formation rate based on mass and energy balance. Hence I require UDF macros for species mass fractions, temperature, density etc which are readily available for access. But there no details available on UDF macros for obtaining the data from Radiation results such as Incident Radiation, Volumetric Emitted/Absorbed Radiation etc. If anyone knows UDF macros for the above-mentioned data could you kindly share them me?
Regards, Krishna Prasad. G |
macro, radiation do model, udf and programming |
Discrete Phase: UDF for particle break-up | wux | FLUENT | 0 | October 31, 2013 06:58 |
Some guidance is needed about UDF macros | highhopes | Fluent UDF and Scheme Programming | 2 | July 3, 2012 09:41 |
UDF: Previous time step macros NOT working | jpapg | FLUENT | 0 | April 30, 2011 21:35 |
A question about discrete adjoint method | Thomas | Main CFD Forum | 3 | August 9, 2006 12:37 |
Discrete element method? | Ki Ha Hong | Main CFD Forum | 1 | May 28, 1999 09:46 |
