Moving mesh using UDF Define grid motion and Remeshing dynamic mesh |
July 4, 2019, 22:49 |
nguyenhoa
Rep Power: 7 |
Hi everybody
I am facing to a dynamic meshing problem that has not yet found a solution. Hope someone can help me find a solution! Geometric model of the problem as figure attached below. The content mainly focuses on the red border, which is moving in each calculation time step. At time "t0", this boundary is in position 0-0. After each time step "t", this boundary moves a length "s = u * t" with u being a given displacement velocity. thus, at the time "t1 = t0 + t" it will move to position 1-1, "t2 = t0 + 2t" will reach position 2-2, ... similarly until "t13", it will reach position 13-13 and stop moving. The law of moving is similar to using offset tools in other CAD software, so this boundary in the moving process will be shortened over time. I have read and know the function udf DEFINE_GIRD_FUNCTION can describe this moving but I could not find the rule to write how to move. Can someone help me find a solution, thank you very much |
define gird motion, dynamic meshing, moving mesh, udf |
UDF Define grid motion and Remeshing dynamic mesh | nguyenhoa | Fluent UDF and Scheme Programming | 6 | July 20, 2023 02:41 |
dynamic mesh using define grid motion udf | fredrick | Fluent UDF and Scheme Programming | 15 | December 21, 2020 17:06 |
Dynamic Mesh: Remeshing doesn´t work properly | maccheese | Fluent Multiphase | 4 | June 7, 2018 05:56 |
UDF Problem about Grid Motion !!! | Zhengyu Gao | Fluent UDF and Scheme Programming | 0 | December 6, 2013 19:45 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
