Adding a source term in Fluent_(real dS[])
Old   May 16, 2023, 12:31
Default Adding a source term in Fluent_(real dS[])
Raja Ganesh
Raja23 is on a distinguished road
Hello everyone,
I am new to UDF and I am working on adding a source term to a VOF model. I am trying to understand the "real dS[]" term. On going through the Fluent UDF manual, I understood that this is a derivate term of the dependent variable in the transport equation. But I am not clear about the two options that Fluent provides,
ds[equ] = ds/d(phi) (for implicit)
ds[equ] = 0.0 (for explicit).
Can someone explain, when should i choose the derivate term to be the real derivate and when should i just enter 0.0 as the derivative value? Thanks.
Raja23 is offline   Reply With Quote
derivative, fluent - udf, source code, udf code, udf c_vof
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 16:05
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
