September 6, 2019, 09:52 |
Porosity based solid UDF
Robin
Rep Power: 6 |
Hi all,
First of all, excuse me if I make some mistakes concerning the thread/forum rules as this is my first ever created thread (mainly because I am unable to find any useful answer to my problem ). Given the problem, I want to try and simulate the open/closing of a door (which will be used in a large simulation eventually) in ANSYS Fluent. There are (which I am aware of) mainly two ways of doing this. The first option is to use a dynamic mesh in which a UDF is used describing the required translation/rotation. This I am able to (partially) do, however I notice that I need an extremely small time step as it is transient. Hence I 'discovered' a second option used in a research ('CFD SIMULATION OF AIRFLOW DUE TO DOOR MOTION USING A MOMENTUM SOURCE METHOD.'). In this study, it is explained that a door/solid can be modeled by a UDF which specifies a porosity of 0% at the location of the door. Therefore creating a somewhat artificial solid (velocity is zero at this location). However, after trying to implement it in Fluent, I came to the conclusion that it is (most likely) impossible to have a porosity equal to 0 as it gives the 'floating point' error. I should note, that I first simplified the problem to steady state, in which I (try to) simulate the flow of a fluid around a solid square using this 'artificial' technique (afterwards I wanted to make this solid move by means of a path defined in the UDF, becoming transient). The UDF I use is given as: #include "udf.h" DEFINE_PROFILE(POR_solid,thread,i) { cell_t cell; real x[ND_ND]; begin_c_loop(cell,thread) { if (x[1] <= 0.2 && x[1] > -0.2 && x[0] >= -0.2 && x[0] < 0.2) */Square location */ { F_PROFILE(cell,thread,i) = 0.0; } else { F_PROFILE(cell,thread,i) = 1.0; } } end_c_loop(cell,thread) } My question is therefore, is it possible to still construct a UDF which uses this method without getting the 'floating point' error (note that upon changing the zero value to an arbitrary nonzero value, fluent is able to solve the problem). Again, Sorry if I posted this in the wrong thread . Some extra info: I interpret the UDF rather than compiling. Next, I implement it by going to (in fluent) Cell zone Conditions -> edit -> porous zone -> X direction-1 vector Robin |
September 23, 2019, 03:03 |
Alexander
Rep Power: 34 |
you may try to use very small timesteps to reach the convergence
also you should think about inlets and outlets in your model best regards |
porous media, udf |
porosity udf | walied123 | Fluent UDF and Scheme Programming | 4 | February 17, 2015 14:34 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
UDF : heat source located in a solid | cdiako | Fluent UDF and Scheme Programming | 7 | October 8, 2013 18:56 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 13:58 |
porosity in UDF | Jin Yan | FLUENT | 4 | December 1, 2009 09:27 |
