How to write a UDF for a heat source attached to a moving particle in Fluent?
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   September 30, 2019, 07:46
Default How to write a UDF for a heat source attached to a moving particle in Fluent?
Subham
subham998 is on a distinguished road
The cross-section of the domain is similar to a pipe. The objective is to heat metal particles located at a certain distance from the inlet of the pipe using a specified value of heat flux. I don't know the resulting temperature so I cannot specify the temperature of the particle using DPM Source Macro as:
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_SOURCE(dpm_source,c,t,S,strength,p)
real xc[ND_ND]; // array of cell coordinates
C_CENTROID(xc,c,t); // retrieves the cell coordinates
if (xc[0] > 3) // only if this cell belongs in the domain where x > 3 m
P_T(p) = 500; //temperature of the metal particle increases to 500K
Any Suggestions?
subham998 is offline   Reply With Quote
Old   October 1, 2019, 03:32
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you can use source term as mass, momentum and energy exchange terms for coupled DPM calculations
I'm not sure about syntax but idea is:
#include "udf.h"
#include "dpm.h"
S->energy = 500; //heat source 500W/m3
if S->energy doesn't work, try other approach
#include "udf.h"
#include "dpm.h"
real source = 0.0;
 source = 500; //heat source 500W/m3
return source;
best regards
subham998 likes this.
AlexanderZ is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
