October 3, 2019, 08:36 |
Updating the nodes of the mesh: why?
Josh
Rep Power: 7 |
Hi guys,
I need an explanation about UDF. Take a look at this topic: CG Motion UDF Problem I use something very similar to this: I define a sinusoidal function for the velocity along x-axis, I compile the udf and decide what part of my mesh I want to move. It works perfectly: the wall moves back and forth along x-axis. However in fluent manual, just like in this other thread: dynamic mesh using define grid motion udf there is a part of the code where the node are updated. The fact is that I never do that and I do not have any kind of problem... but I do not know why. So is this part of the code really necessary? Yes, no, else...? I do not understand what this is used for. I do not do it and I have a perfect dynamic mesh layering. Regards |
dynamic mesh, grid motion, layering, udf code |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Some questions about mesh updating in dynamic mesh technique | lzgwhy | Main CFD Forum | 0 | June 14, 2009 08:01 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
