Journal process getting stuck on pop-up window
Old   October 19, 2019, 13:21
Default Journal process getting stuck on pop-up window
Daniel
dsaen is on a distinguished road
I have this journal file which I'm using to alternate the boundary condition on a surface between an imposed heat flux (coming from a profile file) and a convection condition.
I must a apply the heat flux load for a specified amount of time, then let it cool for another amount of time, and repeat this cycle a number of times. The journal file takes care of making the change in BC's conditions and running the simulation. However each time the BC's conditions are changed and I try to run again, this warning window pops up telling me that the 'Settings have changed!', effectively stopping the process until a manual selection is made:
Despite the fact that it is being considered in the Journal code:
(cx-gui-do cx-activate-item "Settings have changed!*PanelButtons*PushButton1(OK)")
What is happening here? How can I avoid this problem?
Complete file:
/file/set-tui-version "19.0"
(do ((x 1 (+ x 1))) ((> x 100))
	(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Setup|Boundary Conditions|flux (wall, id=7)"))
	(cx-gui-do cx-activate-item "NavigationPane*List_Tree1")
	(cx-gui-do cx-set-toggle-button2 "Wall*Frame3*Frame2(Thermal)*Frame1*Frame1(Thermal Conditions)*ToggleBox1*Heat Flux" #t)
	(cx-gui-do cx-activate-item "Wall*Frame3*Frame2(Thermal)*Frame1*Frame1(Thermal Conditions)*ToggleBox1*Heat Flux")
	(cx-gui-do cx-activate-item "Wall*PanelButtons*PushButton1(OK)")
	(cx-gui-do cx-activate-item "Run Calculation*Table1*PushButton22(Calculate)")
	(cx-gui-do cx-activate-item "Information*OK")
	(cx-gui-do cx-set-toggle-button2 "Wall*Frame3*Frame2(Thermal)*Frame1*Frame1(Thermal Conditions)*ToggleBox1*Convection" #t)
	(cx-gui-do cx-activate-item "Wall*Frame3*Frame2(Thermal)*Frame1*Frame1(Thermal Conditions)*ToggleBox1*Convection")
dsaen is offline   Reply With Quote
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 14:05
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 17:08
[ICEM] Script file : how to reset all, fit window, etc. macfly ANSYS Meshing & Geometry 0 July 25, 2012 11:07
Interrupting a Journal File svp FLUENT 2 February 16, 2011 08:00
[GAMBIT] auto close Gambit window MEDI ANSYS Meshing & Geometry 1 September 3, 2010 06:18
