November 25, 2019, 23:45 |
DEFINE_PROFILE parallelization problem
Beichao Hu
Rep Power: 8 |
Hello everyone
I am trying to write a UDF to make one of the mass flow inlet boundary equal to the flow rate of another pressure outlet. I have problem with the parallelization. My code works in serial mode, but it always fail to initialize in the parallel mode. The error message is always segmentation fault. I have tried to initialize the case first and then load the UDF, but it did not work either. I have been stuck in this problem for a few days, any help is appropriated. Thanks in advance. #include "udf.h" #include "mem.h" #include "sg.h" #include "prop.h" int pdu_out = 12; DEFINE_PROFILE(pdu_leakage,th,i) { real pdu_mfr = 0.0; int surface_thread_id = pdu_out; #if !RP_HOST Thread *thread; face_t face; Domain *d; #endif host_to_node_int_1(surface_thread_id); #if !RP_HOST d = Get_Domain(1); thread = Lookup_Thread(d,surface_thread_id); begin_f_loop(face, thread) if (PRINCIPAL_FACE_P(face,thread)) { pdu_mfr += F_FLUX(face,thread); } end_f_loop(face, thread); # if RP_NODE pdu_mfr = PRF_GRSUM1(pdu_mfr); #endif #endif node_to_host_real_1(pdu_mfr); #if !RP_HOST begin_f_loop(face, th) if(PRINCIPAL_FACE_P(face,th)) { F_PROFILE(face, th, i) = pdu_mfr; } end_f_loop(face,th); #endif } |
November 26, 2019, 03:34 |
Alexander
Rep Power: 34 |
#include "udf.h" #include "mem.h" #include "sg.h" #include "prop.h" int pdu_out = 12; DEFINE_PROFILE(pdu_leakage,th,i) { real pdu_mfr = 0.0; int surface_thread_id = pdu_out; Thread *thread; face_t face; Domain *d; d = Get_Domain(1); thread = Lookup_Thread(d,surface_thread_id); begin_f_loop(face, thread) if (PRINCIPAL_FACE_P(face,thread)) { pdu_mfr += F_FLUX(face,thread); } end_f_loop(face, thread); # if RP_NODE pdu_mfr = PRF_GRSUM1(pdu_mfr); #endif begin_f_loop(face, th) if(PRINCIPAL_FACE_P(face,th)) { F_PROFILE(face, th, i) = pdu_mfr; } end_f_loop(face,th); }
best regards ****************************** press LIKE if this message was helpful |
November 26, 2019, 10:20 |
#3 | |
Beichao Hu
Rep Power: 8 |
Thank you for you help. The problem is solved. |
define profile, parallel code |
Problem with parallelization and a constant field located at constant folder | rucky96 | OpenFOAM | 7 | January 29, 2021 16:54 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
