May 29, 2020, 12:44 |
Error with UDF for Cp in terms of LIQF
Rep Power: 16 |
Dear all
I tried to interpret the below UDF for specific heat Cp in terms of liquid fraction that used in Solidification/Melting model the UDF as below: #include "udf.h" DEFINE_SPECIFIC_HEAT(specificheat, T, Tref, h, yi) { #if !RP_HOST real cpm,dt; Tref=308; real cps = 1800.0; real cpl = 2400.0; real lat = 160000.0; real LIQF = C_T(cell, thread); dt=exp(-T*(T-Tref)*(T-Tref)/4.0)/sqrt(4.0*3.14); cpm =cps+(cpl-cps)*C_LIQF(c,t)+lat*dt; *h = cpm*(T-Tref); return cpm; #endif } The problem I got the following errors with unknown reason: Error: C:/Users/DELL/AppData/Local/Temp/cp.c.32836.11.c: line 7: parse error. Error: C:/Users/DELL/AppData/Local/Temp/cp.c.32836.11.c: line 8: parse error. Error: C:/Users/DELL/AppData/Local/Temp/cp.c.32836.11.c: line 9: parse error. Error: C:/Users/DELL/AppData/Local/Temp/cp.c.32836.11.c: line 10: parse error. Error: C:/Users/DELL/AppData/Local/Temp/cp.c.32836.11.c: line 12: cps: undeclared variable Any suggestions, please? Mariam |
May 29, 2020, 12:57 |
Specific Heat
DEFINE_SPECIFIC_HEAT is not executed at cell level like DEFINE_PROPERTY. That's why it requires a separate function while most of the other properties can be modeled using DEFINE_PROPERTY. It executes at material level and does not have access to cell and thread. C_T returns temperature of a cell but that is already available in form of T. If you are solving for species transport, then their mass fractions are available as yi. But you cannot access C_LIQF because its arguments are not available.
Lastly, you cannot interpret it. It must be compiled.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 29, 2020, 13:01 |
#3 | |
Rep Power: 16 |
Do you mean I need to use compile to implement this UDF? regards |
May 29, 2020, 13:28 |
Udf
You need to make changes to the UDF and then compile it. You cannot use C_T and C_LIQF. Those are not available within specific heat function.
May 29, 2020, 14:40 |
Rep Power: 16 |
Actually I am not that familiar with UDF hence I have no idea what to do with C_T and LIQF? any suggestions are highly appreciated?
Regards |
May 29, 2020, 14:46 |
C_T and LIQF
C_T and C_LIQF are macros that return temperature and liquid fraction in a cell. However, cell temperature is already available as T, in case you need it to define specific heat. But you cannot access C_LIQF even if you need it. It all depends on the equation you have for specific heat. Does the equation require value of liquid fraction or temperature or not?
May 29, 2020, 15:08 |
#7 | |
Rep Power: 16 |
May 29, 2020, 15:15 |
Equation
May 29, 2020, 15:50 |
#9 |
Rep Power: 16 |
f(T) is the liquid fraction
deltaT is constant as 2 C |
May 29, 2020, 16:12 |
Liquid Fraction
#10 |
That means = C_LIQF, however, you cannot access C_LIQF within DEFINE_SPECIFIC_HEAT. So, you have to define liquid fraction, somehow, in terms of T. Anyway, it is a function of T, that's why .
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 08:33 |
UDF source terms | Andrew Garrard | FLUENT | 1 | October 30, 2003 10:48 |
UDF for source terms | Tom | FLUENT | 1 | April 26, 2002 01:13 |
Convection Terms in UDF | Jon Thorpe | FLUENT | 1 | August 14, 2000 09:41 |
