Divergence & Floating Point Error on using UDF
Old   June 12, 2020, 03:58
Default Divergence & Floating Point Error on using UDF
Morice is on a distinguished road
Hey guys,
The UDF is an energy and water vapour source UDF and I keep getting a floating-point error and divergence on temperature and water vapour when I try to run the simulation.
I have done the math in C++ and Matlab and the math is correct.
Maybe there is an issue with the thermodynamics that am not seeing.
Honestly, I have no idea what the issue could be.
Thanks so much, much appreciated.
 #include "udf.h"
#include "math.h"
#define ra 271           /*aerodynamic resistance*/
#define lad .3033        /*leaf area demsity*/
#define kc  .95        /*extinction coefficient of the canopy*/
#define hgt 1.5         /*height of the canopy*/
#define Cp  1006.43     /*specific heat of dry air*/
#define rho 1.225       /*density of dry air*/
#define lai .24271      /*leaf area index*/
#define c3  18.6
#define c4  197.5
#define c5  .31
#define c6  1.2e-6
#define lamda 2.450e6       /*latent heat of vaporisation*/
#define gamma 67.381125     /*psychrometric constant*/
#define ks    0.7           /*coefficient of shading screen*/
/*VARIABLES THAT NEED TO BE MODIFIED BEFORE EVERY SIMULATION*/
#define rgo  43.28        /*global radiation above the canopy*/
DEFINE_INIT(initial_values, domain)
	cell_t c;
	Thread* t;
	thread_loop_c(t, domain)
		begin_c_loop(c, t)
			C_UDMI(c, t, 0) = 288.15;           /*Ta*/
			C_UDMI(c, t, 1) = 1699.81;         /*Psat*/
			C_UDMI(c, t, 2) = 289.15;          /*Temperature of leaf in cropzone1*/
			C_UDMI(c, t, 3) = 60.497;          /*rs1*/
			C_UDMI(c, t, 4) = 331.495;         /*rt1*/
			C_UDMI(c, t, 5) = 6.19434;         /*ET1, Qlat1*/
			C_UDMI(c, t, 6) = 292.226;         /*Tlr1; Real leaf temp cropzone1*/
			C_UDMI(c, t, 7) = 7.66834e-7;      /*cropzone1 water vapour mass fractions source*/
			C_UDMI(c, t, 8) = 289.15;          /*Temperature of leaf in cropzone2*/
			C_UDMI(c, t, 9) = 60.4947;         /*rs2*/
			C_UDMI(c, t, 10) = 331.495;         /*rt2*/
			C_UDMI(c, t, 11) = 7.66834e-7;      /*cropzone2 water vapour mass fractions source*/
			C_UDMI(c, t, 12) = 292.226;         /*Tlrl; Real leaf temp crop zone2*/
			C_UDMI(c, t, 13) = 6.19434;         /*ET2, Qlat2*/
		end_c_loop(c, t)
DEFINE_ADJUST(ta_calc, d)
	Thread* t;
	cell_t c;
	thread_loop_c(t, d)
		if(THREAD_ID(t)==7)
		begin_c_loop(c,t)
			double Ta,Psat;
			Ta += C_T(c, t) * C_VOLUME(c,t);
			C_UDMI(c, t, 0) = Ta;
			Psat = 610.78 * exp((17.25 * (Ta - 273.15)) / (237.8 + (Ta - 273.15)));
			C_UDMI(c, t, 1) = Psat;
		end_c_loop(c,t)
DEFINE_SOURCE(cropzone1_h20_source, c, t, dS, eqn)
	double a, rs1, rt1, hcv1, Tl1, Tl1r, Plsat1, vpd1, ET1, Sw1, St1;
	real con, source;
	real x[ND_ND];
	C_CENTROID(x, c, t);
	con = rgo * ks * exp(-kc * lad * (((hgt - x[1]) / hgt)));
	Tl1 += C_T(c, t) * C_VOLUME(c, t);
	C_UDMI(c, t, 2) = Tl1;
	Plsat1 = 610.78 * exp((17.25 * (Tl1 - 273.15)) / (237.8 + (Tl1 - 273.15)));
	vpd1 = Plsat1 - C_UDMI(c, t, 1);
	a = con / (2 * lai);
	rs1 = c3 * ((a + c4) / (a + c5)) * (1 + (c6 * vpd1 * vpd1));
	C_UDMI(c, t, 3) = rs1;
	rt1 = ra + rs1;
	C_UDMI(c, t, 4) = rt1;
	ET1 = ((rho * Cp) / gamma) * (vpd1 / rt1);
	C_UDMI(c, t, 5) = ET1;
	hcv1 = (rho * Cp) / ra;
	Tl1r = (con - ET1) / ((2 * hcv1) + C_UDMI(c, t, 0));
	C_UDMI(c, t, 6) = Tl1r;
	source = (rho * Cp * lad * vpd1) / (gamma * lamda * rt1);
	C_UDMI(c, t, 7) = source;
	dS[eqn] = (rho * Cp * lad) / (gamma * lamda * rt1);
	return source;
DEFINE_SOURCE(cropzone1_energy_source, c, t, dS, eqn)
	real source;
	source = - C_UDMI(c, t, 7) * lad;
	dS[eqn] = -(rho * Cp * lad) / (gamma * C_UDMI(c, t, 4));
	return source;
DEFINE_SOURCE(cropzone2_h20_source, c, t, dS, eqn)
	double b, rs2, rt2, hcv2, Tl2, Tl2r, Plsat2, vpd2, ET2, Sw2, St2;
	real x[ND_ND];
	real source, con;
	Tl2 += C_T(c, t) * C_VOLUME(c, t);
	C_UDMI(c, t, 8) = Tl2;
	Plsat2 = 610.78 * exp((17.25 * (Tl2 - 273.15)) / (237.8 + (Tl2 - 273.15)));
	vpd2 = Plsat2 - C_UDMI(c, t, 1);
	b = con / (2 * lai);
	rs2 = c3 * ((b + c4) / (b + c5)) * (1 + (c6 * vpd2 * vpd2));
	C_UDMI(c, t, 9) = rs2;
	rt2 = ra + rs2;
	C_UDMI(c, t, 10) = rt2;
	ET2 = ((rho * Cp) / gamma) * (vpd2 / rt2);
	C_UDMI(c, t, 11) = ET2;
	hcv2 = (rho * Cp) / ra;
	Tl2r = (con - ET2) / ((2 * hcv2) + C_UDMI(c, t, 0));
	C_UDMI(c, t, 12) = Tl2r;
	source = (rho * Cp * lad * vpd2) / (gamma * lamda * rt2);
	C_UDMI(c, t, 13) = source;
	dS[eqn] = (rho * Cp * lad) / (gamma * lamda * rt2);
	return source;
DEFINE_SOURCE(cropzone2_energy_source, c, t, dS, eqn)
	real source;
	source = - C_UDMI(c, t, 13) * lad;
	dS[eqn] = -(rho * Cp * lad) / (gamma * C_UDMI(c, t, 10));
	return source;
Morice is offline   Reply With Quote
Old   June 15, 2020, 03:53
Default Divergence
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Do you get divergence at the very first iteration? In that case, you need to ensure that all the denominators are non-zero and all the sources are comparatively small. Since you are using field values in the UDF, a good initial guess is also important. So, you may try running the solution for a few iterations before hooking the source UDFs.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 15, 2020, 23:48
Default Divergence
Morning Vinerm,
Thank you for the response, much appreciated.
The divergence is on the very 1st iteration.
I realized that a good initial guess is important so the initial values I used are those values that I obtained from running the equations in Matlab making sure that the times are the same.
I was thinking of running the solution for a few iterations before hooking the source UDFs but I was not able to find a way to do that.
How is that done? do I stop the calculation, hook up the UDFs then continue the calculation?
Divergence Problem Conjugated Heat Transfer Christoph.Ha FLUENT 27 December 5, 2017 10:46
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
Primitive error at node- Floating point exception / continuity divergence issues phales15 FLUENT 0 April 30, 2011 19:05
divergence in AMG and floating point grzes FLUENT 0 February 17, 2006 13:22
