ShOh
Rep Power: 5 ![]() |
Hello, I would really appreciate if you could give me an answer.
Inside the computational domain, I have a face at which velocity in x direction is 3 m/s. Also, I have to solve passive scalar field, and the scalar boundary condition at the face should be zero flux. Since the face has 2 adjacent cell zones, I first set the face to 'wall' and then 'slit' the face into 2 uncoupled wall zones. Next, I change both two 'wall's to 'velocity-inlet', and impose the velocity of 3 m/s in the x direction for both walls. As done for the velocity, I also impose the zero flux boundary condition for the scalar at both walls. As a result, the fluid seems to 'continuously' flow through the walls, but the problem is the scalar field is not continuous. So, my question is how can I match the scalar distribution at both walls. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Simulating fire in a tunnel | luca1992 | OpenFOAM | 14 | August 16, 2017 13:50 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
