if (NNULLP(T_STORAGE_R_NV(t0, SV_UDSI_G(0))))
Old   October 3, 2020, 07:12
Default if (NNULLP(T_STORAGE_R_NV(t0, SV_UDSI_G(0))))
lbj007 is on a distinguished road
I want to know what will happen if the gradient of uds is not allocated. Can it lead to that all the Statements relevant to C_UDSI_G will not be executed?or something else.
lbj007 is offline   Reply With Quote
Old   October 5, 2020, 01:23
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
NNULLP returns TRUE if storage is allocated for user-defined storage variable
in case the storage has not been allocated if statement will not be executed
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 5, 2020, 22:11
so how do I know the statement is executed, can I add a printf statement to help me judge?so the NNULLP conditional judgment statement just help to let me know the storage has or hasn't been allocated,it won't affect the other code to be executed,am I right?
Old   October 6, 2020, 03:42
Alexander
NNULLP conditional i needed to prevent the case, when you read gradient (or any other variable) value , but memory was not allocated.
In that case you will get an error
you can put printf inside if statement,
it is recommended to use Message macro in fluent instead of printf
best regards
Old   October 6, 2020, 05:58
so if I don't use NNULLP and memory is just not allocated,it will get an error,
then if I use NNULLP and memory is just not allocated,what it would show?
udsi
