How can solve this problem?
Old   October 7, 2020, 23:37
Default How can solve this problem?
hitzhwan is on a distinguished road
Error: The UDF library you are trying to load (libudf) is not compiled for 2ddp on the current platform (win64).\n\n系统找不到指定的文件。
\n\nC:\Users\Administrator\Desktop\libudf\win64\2d dp\libudf.dll
Error Object: #f
hitzhwan is offline   Reply With Quote
Old   October 8, 2020, 00:39
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
compile UDF (press build, not load)
you have this
n系统找不到指定的文件。
cause of not english version of windows, most likely
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 8, 2020, 10:13
Default I have press the build first, and click the load latter, isn't it correct?
you have this
n系统找不到指定的文件。
Hi,Alexander,
I have press the build first, and click the load latter, isn't it correct? Thank you.
Old   October 12, 2020, 05:50
Alexander
so it means, compilation was not successful
read log output in console and fix your UDF
best regards
Old   October 12, 2020, 08:52
Hi, how can I read log output in console and fix your UDF, could you help me?
Old   October 12, 2020, 09:16
pakk will become famous soon enough
You are able to read the words on this forum. Now do the same to the words that show up in Fluent after you click 'build'.
pakk is offline   Reply With Quote
Old   October 12, 2020, 22:05
Alexander
show your UDF, may be we can fix it together
best regards
Old   October 13, 2020, 17:27
Default I have fixed by setting the environment.
Fluent do not use my velocity field(by UDF) to solve energy equation tangleiplus Fluent UDF and Scheme Programming 6 January 21, 2019 21:28
solve equation michaelsmit OpenFOAM Running, Solving & CFD 4 March 24, 2011 05:35
Solve Flow or VOF simultaneously ? Ramsey FLUENT 1 February 16, 2011 13:16
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 06:58
MAC method solve for pressure at boundry Ron Main CFD Forum 2 January 28, 2006 02:14
