Difficulty in loading UDF: udf library not compiled for parallel use |
September 24, 2020, 17:49 |
Rep Power: 7 |
Hi all,
I’m having difficulty debug/load the UDF in my work. The problem description is demonstrated as the following: Background: I’m using mixture model to simulate two liquid phases in a tank. The primary phase is water and the second phase is slightly heavier than water. What I want to do is to “count how much of the second phase fluid can accumulate at the bottom of the tank”. So I understand it as it is similar to degassing boundary condition for air, but in my case, for liquid. I assume if the second phase hit the floor below a certain velocity, I “take it out”. Condition: I have windows 10 64bit OS VS2017 installed. ANSYS 2020R2. Problem: As I was trying to build and load the library with a c file saved in the same directory where the case file is saved, I received this error message: Copied D:\Software\ansys\ANSYS 2020R2\UDF practice/D:\Software\ansys\ANSYS 2020R2\UDF practice estudf.c to libudf\src Creating user_nt.udf file for 3ddp_host ... (system "copy "d:\software\ansys\ansys 2020r2\ansys inc\ansys student\v202\fluent"\fluent20.2.0\src\udf\makefile _nt.udf "libudf\win64\3ddp_host\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_host")# Generating ud_io1.h testudf.c # Generating udf_names.c because of makefile testudf.obj udf_names.c # Linking libudf.dll because of user_nt.udf udf_names.obj testudf.obj Microsoft (R) Incremental Linker Version 14.16.27043.0 Copyright (C) Microsoft Corporation. All rights reserved. LINK : fatal error LNK1104: cannot open file 'libudf.dll' Creating user_nt.udf file for 3ddp_node ... (system "copy "d:\software\ansys\ansys 2020r2\ansys inc\ansys student\v202\fluent"\fluent20.2.0\src\udf\makefile _nt.udf "libudf\win64\3ddp_node\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_node")# Generating ud_io1.h testudf.c ..\..\src\testudf.c(13): warning C4003: not enough arguments for function-like macro invocation 'THREAD_SUB_THREAD' ..\..\src\testudf.c(13): error C2059: syntax error: ']' I also received this message if I tried to click load. Question: I noticed that there are bugs. i.e. not enough arguments for function-like macro invocation ‘THREAD_SUB_THREAD’. However, I’m not sure where did I make the mistake. Also in regards of the syntax error: ‘]’, I do not have ‘]’ in that line. Also, can someone help me understand what does it mean in the error message and how to resolve it? What I have tried: 1. Open Fluent from VS Command Prompt 2. Making sure all the files (cas,dat,c) are in the same location 3. Run this in parallel with multiple cores. 4. Making sure that visual C++ is installed. Attached is my udf file. Any help is highly appreciated! |
September 25, 2020, 13:18 |
Managed to build and load facing UDMI problem
Rep Power: 7 |
Hi all,
So I managed to modify and code and make it work for serial processing for now. I am able to build and load the library in ANSYS 2020R2. However, as I tried to initiate the computation, I received an error message like: Node 0: Process 20628: Received signal SIGSEGV. I set the UDM locations to 6 before I load the library, as I put 5 in the C_UDMI(c,t,i). (I'm not sure how to determine what your index i should be...) Can anyone help me? |
October 5, 2020, 03:00 |
Alexander
Rep Power: 34 |
try this code,
its enough to allocate only one udmi memory location for this UDF Code:
#include "udf.h" DEFINE_ADJUST(my_adjust1, d) { Thread *t, **pt; cell_t c; t = Lookup_Thread(d, 9); begin_c_loop(c, t) { C_UDMI(c,t,0)=0.0; pt=THREAD_SUB_THREAD(t); if (C_V(c, pt[1]) < -0.15) C_UDMI(c, t, 0) = 227.27*C_R(c, pt[1])*C_VOF(c, pt[1])*C_V(c, pt[1]); } end_c_loop(c, t) } DEFINE_SOURCE(bot_source1, c, t, dS, eqn) { real source; Thread *super_t = THREAD_SUPER_THREAD(t); source = (-1.0*C_UDMI(c,super_t,0)); return source; } DEFINE_INIT(my_init_func,d) { Thread *t, **pt; cell_t c; thread_loop_c(t,d) { /* loop over all cells */ begin_c_loop_all(c,t) { C_UDMI(c,t,0) = 0.0; } end_c_loop_all(c,t) } }
best regards ****************************** press LIKE if this message was helpful |
October 7, 2020, 09:03 |
Rep Power: 7 |
Hi, thank you very much for the code! However, I'm still getting the error message: Node 0: Process XXXXX: Received signal SIGSEGV
I tried making the C_UDMI a constant and it does not report error. I assume there is something wrong with the formula for C_UDMI. I wanted to calculate the mass flow rate at the wall boundary which will be (\rho*vof_2nd phase*v_vertical*Area. The area should be the area of the rectangular cell surface perpendicular to the y_axis. I'm not sure how can I get that... Any help would be highly appreciated! |
October 7, 2020, 21:53 |
#5 | |
Alexander
Rep Power: 34 |
well, now I can see, the problem comes from pt[1]
why are you trying to use it? change pt[1] to t everywhere. the other important thing is Quote:
2. if you want to calculate mass flow rate on the surface, you need loops over faces (and adjusted cells) , not cells. 3. once you've made t =9 , you defined that loop will be in thread with ID = 9, and for your code it should be some zone, not boundary
October 8, 2020, 17:53 |
Rep Power: 7 |
I think I should explain the problem better in this way: I use mixture model to simulate flow with two different fluids. What I'm trying to do is that I want to remove the second fluid that "hits" the bottom floor with a certain vertical velocity(assume 0.0 m/s). So the C_UDMI calculates the flux of the second phase that needs to be removed. I shouldn't have said it as "to calculate the mass flow rate at the wall boundary" To answer some of your questions: 1. I used pt[1] because I need to read some variables of the second phase like density, volume fraction, vertical velocity. I'm not sure if I'm only using t, one pointer, how can I read the second phase properties only? 2. I loop over the cell because my understanding is that the values are stored in the cells? The source term was eventually hooked up in cell zone. So I'm not actually getting the velocity from the wall, but read it from the cell at the ID=9. Here is the code that I successfully compiled but still having issues with the error message I mentioned above: Code:
#include "udf.h" DEFINE_ADJUST(my_adjust1, d) { Thread *t, **pt; face_t f; cell_t c; t = Lookup_Thread(d, 9); begin_c_loop(c, t) { C_UDMI(c,t,0)=0.0; pt=THREAD_SUB_THREADS(t); if (C_V(c, pt[1]) < 0.0) C_UDMI(c,t,0) = -1.368*C_R(c, pt[1])*C_VOF(c, pt[1])*C_V(c, pt[1]); } end_c_loop(c, t) } DEFINE_SOURCE(bot_source1, c, t, dS, eqn) { Thread *super_t = THREAD_SUPER_THREAD(t); return (-1.0*C_UDMI(c,super_t,0)); } My apologies, I'm new to UDF. Thank you for being so patient with me. |
October 12, 2020, 06:12 |
Alexander
Rep Power: 34 |
thread pt is not defined in your code, which supposes to lead to error
try to add Code:
**pt = THREAD_SUB_THREADS(t);
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 08:33 |
UDF compiled and loaded but not available | Easyeight | Fluent UDF and Scheme Programming | 7 | June 28, 2018 11:54 |
Problem loading UDF in Linux environment | hjan23 | FLUENT | 0 | December 15, 2017 04:09 |
Loading library via scheme command | crevoise | Fluent UDF and Scheme Programming | 3 | March 31, 2017 06:50 |
setting up compiled UDF library in windows2000 | sivakumar | FLUENT | 1 | October 19, 2001 03:46 |
