Fluent crashes with 999999: mpt_accept: error: when using C_VOF command in UDF |
November 10, 2020, 07:29 |
Santhosh
Rep Power: 8 |
I am trying to make an UDF for additive manufacturing (material deposition on a flat plate) where there is moving heat source on the substrate and mass source added to the melt pool. For this I need to locate the interfacial cells using this command if(C_VOF(cell,sec_th)>0.05 && C_VOF(cell,sec_th)<1). This command works well for the energy source term. However, if I use the same command for the mass source term fluent crashes with 999999: mpt_accept: error: (Node 0: Process xxxx: Received signal SIGSEGV). Can anyone kindly help me solve this issue?
fluent - udf, moving heat source, udf c_vof |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Problem running fluent with udf on batch | tobi b. | Fluent UDF and Scheme Programming | 3 | April 14, 2016 13:54 |
implementing UDF for fluent in workbench for running multiple simulations | faizan_habib7 | Fluent UDF and Scheme Programming | 0 | March 18, 2016 22:29 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
UDF of Zimont model in fluent | Z | Main CFD Forum | 0 | February 17, 2005 03:07 |
