Is it possible to set equations on/off with UDF while solving? |
November 11, 2020, 10:05 |
Hi all,
I would like to solve a problem of two UDS uncoupled since due to coupling the solving time is way too long. Is there a possibility to solve UDS1 for one timestep and then turn of UDS1 and solve for the 2nd timestep UDS2 by using a define adjust UDF? Or is the only way to use a journal file and set simulation time equal one timestep and change the equations after the whole simulation is finished after one timestep? It would be nice to have a way to set the simulation time larger then one timestep. Alex |
November 12, 2020, 03:59 |
Alexander
Rep Power: 34 |
you need journal file for that
run 1 time step simulation several times, to make it longer you may use scheme language inside journals
best regards ****************************** press LIKE if this message was helpful |
November 12, 2020, 05:34 |
thanks a lot!
Yep I sorted it out like that. You helped me quite a lot in my thesis! Could you maybe help me with this problem in the forum for one last time? It is the last step before my setup is finished. Ansys support does not want to help regarding their UDFs :/ Why leads UDS_FLUX Example from User Guide to wrong results? |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
