UDF to calculate torque in 2D blade
Old   November 22, 2020, 22:06
Default UDF to calculate torque in 2D blade
ijama
ijama is on a distinguished road
I would like to seek help on making udf to calculate the torque (from pressure and viscous force) acting on a 2D blade. I know that the value can be easily obtained using Monitor but I need to get the torque value for each time-step so I can use it to adjust the angular velocity later(not in the code yet). I keep on getting error on line 30 "NV_S(force_v, =, F_STORAGE_R_NV(f,t,SV_WALL_SHEAR),*,-1.0);".
I pasted the code below, thank you in advance for your help.
# include "udf.h"
DEFINE_EXECUTE_AT_END(torque_time)
Domain *d = Get_Domain(1);
Thread *t = Lookup_Thread(d,5);
face_t f;
real NV_VEC(A);
real NV_VEC(force_p);
real NV_VEC(force_v);
real NV_VEC(torque_p);
real NV_VEC(torque_v);
real x[ND_ND];
real NV_VEC(radius);
real NV_VEC(torque_final);
real tor;
NV_S(force_p,= ,0.0);
NV_S(force_v,=,0.0);
NV_S(torque_final,=,0.0);
NV_S(torque_p,=,0.0);
NV_S(torque_v,=,0.0);
begin_f_loop(f,t)
F_AREA(A,f,t);
F_CENTROID(x,f,t);
NV_S(force_p,= , F_AREA(A,f,t), * , F_P(f,t));
NV_D(radius,= ,x[0],x[1],x[2]);
NV_CROSS(torque_p,radius,force_p);
NV_CROSS(torque_v,radius,force_v);
NV_VV(torque_final,= ,torque_final,+, torque_p,+,torque_v);
tor= NV_MAG(torque_final);
end_f_loop(f,t)
printf("Torque is = %g", tor );
ijama is offline   Reply With Quote
Old   November 23, 2020, 01:58
pakk will become famous soon enough
Make sure to compile it ("build"), not interpret.
pakk is offline   Reply With Quote
Old   November 23, 2020, 08:21
ijama
Hello pakk,
Thank you for your reply. Yes I did both compiled and interpret but did not work.
Old   November 24, 2020, 00:55
And which error do you see exactly when you compile?
UDF for multiphase species transport (calculate the thread face temperature and press sajaalrifai Fluent Multiphase 10 March 5, 2020 11:01
sharing code to calculate PMV, PPD and PD in fluent using UDF simon02200059 Fluent UDF and Scheme Programming 2 June 24, 2019 01:02
How to calculate number density in breakup rate UDF? masoud.ravan Fluent UDF and Scheme Programming 0 April 4, 2018 03:56
How to calculate torque of the shaft for turbines in CFD fluent simulation ? jeevmech FLUENT 0 September 24, 2016 23:30
UDF to calculate phase-averaged turbulence variables in a periodic flow ShuangqingXu Fluent UDF and Scheme Programming 0 October 26, 2011 23:48
