particle diffusion with wall interactions
Old   December 1, 2020, 11:34
Default particle diffusion with wall interactions
L.A.Isanka
Achini is on a distinguished road
Hello!
I am working on a problem in which nanoparticles diffuse in a channel while having van der waals interactions with the channel wall. should I use the species transport model and use combine a UDF to include particle wall forces,
or can I use a UDF with the DPM model without using the species transport model?
Please suggest a method.
These are polystyrene particles are in a liquid medium.
I am already working on a UDF to include particle wall interactions with DPM model, where particles are given a velocity to flow through the channel.
But instead of that, I need to make particles flow through the channel via diffusion. I want to include a body force to the diffusing particles.
How can I do that?
Thank you!
Achini is offline   Reply With Quote
body force, diffusion, species model
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 13:30
Particle Deposition, Diffusion, Interception abcdefgh Main CFD Forum 2 November 16, 2018 00:26
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 09:46
Particle diffusion in icoLagrangianFoam chegdan OpenFOAM Programming & Development 2 February 24, 2011 13:19
