How to access particle diameter in DPM_BC macro
Old   December 14, 2020, 09:23
Question How to access particle diameter in DPM_BC macro
Alexandre M S Costa
amscosta is on a distinguished road
Hi All,
I want to trap particles at wall based on a given particle diameter.
How can I modify DPM_BC macro below for acquiring that :
DEFINE_DPM_BC(bc_trap,tp,t,f,f_normal,dim)
if (your condition)
if(TP_TYPE(tp) == DPM_TYPE_INERT)
tp->gvtp.n_trapped += 1;
tp->gvtp.n_escaped -=1 ;
return PATH_END ;
Trap_Particle (tp);
else
Your_rebound_function(tp);
return PATH_ACTIVE;
Note : the snippet above is from a solution provided somewhere else. I believe
the line "if (your condition)" is the solution, but I have no idea how to specify "your condition" properly, for instance, how to refer to a particle diameter in the dpm udf language.
Any comment from the skilled users is very welcome.
amscosta is offline   Reply With Quote
Old   December 14, 2020, 09:34
pakk will become famous soon enough
In such a case you just open the Fluent manual...
Look at "Data access macro's", more specific "Model-Specific Macros".
pakk is offline   Reply With Quote
Old   December 14, 2020, 10:15
Alexandre M S Costa
Thanks. I am going try to dig the manual. In the meantime, I found a example
for "your condition" in the attached picture.
File Type: png Captura de tela de 2020-12-14 12-10-41.png (72.4 KB, 25 views)
dpm boundary condition
What is the difference between pore diameter and particle diameter in porous media? Emara FLUENT 6 January 10, 2016 11:01
Access particle data from functionObject CedricVH OpenFOAM 10 July 21, 2011 12:03
Access to the particle position and velocity Christoph_84 OpenFOAM 0 September 30, 2010 09:58
Get direct access to a particle gruber OpenFOAM 3 November 3, 2009 05:26
UDF Data Access Macro Woo Meng Wai FLUENT 0 November 6, 2007 20:23
