January 7, 2021, 03:50 |
velocity slip and temperature jump
zhangdongjie
Rep Power: 5 |
I'm simulating a nozzle with rarefied gas. Its kn number is very large. First order slip and temperature jump must be added. I use Maxwell slip equation to write UDF, but I don't know where UDF should be loaded. I look up the data. The sliding speed can be loaded into the shear stress, so where is the temperature jump loaded? Is it loaded directly into the wall temperature? But my wall temperature is fixed at 300K. If anyone has a compiled UDF file, can you send me one? Thank you very much.1248385182@qq.com
January 7, 2021, 07:05 |
Rep Power: 26 |
I hope you are aware of the low-pressure boundary slip option in Fluent. If not, look it up in the manual, it will simplify your problem a lot.
January 8, 2021, 03:38 |
zhangdongjie
Rep Power: 5 |
Thank you very much for your reply. I watched the low pressure boundary slip, which helped me a lot. But it seems that fluent 2D doesn't have the low-pressure boundary slip button, only 3D does. What should I do. In addition, if I use the low-pressure boundary slip to calculate, is it different from UDF?
January 10, 2021, 06:13 |
Rep Power: 26 |
A UDF is something that you program. You tell the UDF what yo do. So if you want the UDF to be different, it can be different. If you want it to be the same, it can be the same (with some work).
Velocity slip and temperature jump UDF | zhangdongjie | FLUENT | 1 | October 15, 2021 03:17 |
How to set slip velocity and temperature jump | awuunity | CFX | 10 | July 2, 2018 08:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Implementation of maxwell slip velocity and Temperature jump with openfoam | yassepid | OpenFOAM | 2 | June 28, 2016 07:05 |
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. | dayashankar | FLUENT | 1 | May 18, 2016 21:45 |
