UDF- how to calculate the number of particles in DPM |
July 23, 2012, 02:32 |
Andreas Sun
Rep Power: 13 |
Hi everyone,
I am using UDF to do a transient Dust Load Simulation for Air Cleaner(as SAE paper 2006-01-1316 describled), both DPM and UDF are new to me, so I hope I can get some help here. I have particles with 4 different size injected in, and they will all pass through a internal surface boundary condition. I need compute their distribution on this surface. So, first, I want to calculate the number of particles of each size, and then their mass. Can anyone tell me how to calculate the number of DPM particles in UDF? Thanks a million in advance. |
April 8, 2013, 09:04 |
Astio Lamar
Rep Power: 14 |
Hello causuya
Do you find any solution for calculate the number of DPM particles in UDF? I am stuck in a same situation. thanks. |
April 8, 2013, 22:34 |
#3 | |
Rep Power: 17 |
#include "udf.h" #define FACE_ID 4 /*id of your internal face*/ #define TOTAL_INJECTIONS 4 char* Injection_names[TOTAL_INJECTIONS]={"injection-0","injection-1","injection-2","injection-3"}; //injection names in your setup int total_particles[TOTAL_INJECTIONS]={0}; // particles from each injection real total_mass[TOTAL_INJECTIONS]={0.0}; // mass from each injection DEFINE_DPM_SCALAR_UPDATE(calc_size,c,t,initialize, p) { int i; face_t f; Thread*tf; Domain*domain; domain=Get_Domain(1); tf=Lookup_Thread(domain,FACE_ID); begin_f_loop(f,tf) { if(F_C0(f,tf)==c && THREAD_ID(t)==THREAD_ID(THREAD_T0(tf))) /* if c is neighbor to your internal face*/ { Message0("current particle's inject name is %s, mass is %g\n",p->injection->name,P_MASS(p)); for(i=0;i<TOTAL_INJECTIONS;i++) { if(STREQ(Injection_names[i],p->injection->name)) { total_particles[i]++; (total_mass[i])+=P_MASS(p); } } } } end_f_loop(f,tf); } DEFINE_ADJUST(report,domain) { int i; for(i=0;i<TOTAL_INJECTIONS;i++) { Message0("-----------------------------------------------------\n"); Message0("total particles from %s is %d, total mass is %g\n", Injection_names[i],total_particles[i],total_mass[i]); Message0("-----------------------------------------------------\n"); total_particles[i]=0; total_mass[i]=0.0; } } |
April 9, 2013, 04:09 |
Astio Lamar
Rep Power: 14 |
Dear Gearboy
Thanks a lot for your reply. I try to compile the UDF which you offer and I got this error: "The UDF library you are trying to load (libudf) is not compiled for 3ddp on the curent platform (win64). The system cannot find the file specified. " I try to follow the instruction here: http://www.cfd-online.com/Wiki/Fluen...Fload_a_UDF.3F but it doesn't work. any idea to fix it? thanks. |
January 17, 2020, 03:34 |
Erfan Jabari
Rep Power: 6 |
Hello, Gearboy
could you please help me? i need a udf that can calculate the number of trapped particle? thanks alot |
November 26, 2020, 10:29 |
#6 | |
Mraz
Hi Could you find out how to calculate the number of trapped particle? I have a similar problem. That would be great if you help me with this. Thanks |
January 18, 2021, 07:04 |
Dnyanesh Mirikar
Rep Power: 6 |
You can see the number of trapped particles in the DPM summary report. You can go to particle tracking -> select injection -> summary -> display
January 22, 2021, 16:56 |
#8 | |
Mraz
Thank you Dnyanesh for the reply. I am interested to have number of trapped particle over time. The summery just report the total number of trapped particle at the end of calculation. Do you have any suggestion for me? Best, |
January 23, 2021, 13:34 |
#9 | |
Rep Power: 26 |
Write a UDF for a DPM boundary condition, that adds one line to a text file and then traps the particle. The line should contain at least the time of the event, perhaps more of you want more information. Then, use a different program (excel, Matlab, your choice) to do the post-processing. |
DPM: UDF - loop over all particles | chris | Fluent UDF and Scheme Programming | 31 | June 17, 2020 05:52 |
Low Reynolds Number Drag Law - UDF | Daggemann | FLUENT | 0 | April 30, 2009 05:02 |
Pls help: unsteady, DPM, track, particles, number | fivep | Main CFD Forum | 2 | March 7, 2009 00:35 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
DPM - Why do the particles not vanish? | Johannes | FLUENT | 12 | July 6, 2007 11:19 |
