Body motion under multi-moving reference frames |
June 22, 2021, 01:08 |
Rep Power: 4 |
Hi everyone,
From the UDF manual, we know that through using the macro DEFINE_ZONE_MOTION, we can define a moving body that can rotate about a moving point, but it is still not convenient to simulate a moving body that is under multi-superposed motion since we need to update the rotation axises every timestep. So can we define multi-reference frames in this macro or other one? For example, there are a globe frame and a moving frame (frame1) that is superposed by the globe frame, and a second moving frame (frame2) that is superposed by frame1. And finally, we define a reference motion relative to frame2. How can we realize that? Any advice is appreciated. Thank you very much! David |
June 22, 2021, 10:24 |
Rep Power: 4 |
For example, there is a panel rotate about the z1 axis of a reference frame (frame x1y1z1), meanwhile, the frame x1y1z1 also has translation and rotation relative to the XYZ global frame as shown in the following figure.
Why the moving reference frames can be used for unsteady simulation? | Rinia | STAR-CCM+ | 1 | April 12, 2021 09:33 |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Moving Reference Frames. | J Foster | Main CFD Forum | 5 | August 21, 2001 01:13 |
