Save data to excel
Old   February 19, 2022, 14:26
Default Save data to excel
John zink is on a distinguished road
Hi friends
do you know how i can write a udf that save velocitie and reynoldz number values in determined points in porous media in a geometry on 2 columns in excel file?
Thanks
John zink is offline   Reply With Quote
Old   February 21, 2022, 04:22
Jeroen de Graaff
jps115 is on a distinguished road
Hey John,
You can use the typical i/o functions of C to write data to file, such as fprintf (for a text file, easily opened in excel/matlab/...) or fwrite (for a binary file, which is more storage friendly but takes more effort to read, use this if storage is critical)
I would suggest to use txt commands.
/surface/point-surface to specify your sampling point.
/solve/monitors/surface/set-monitor to start writing your sampled quantity to file this will generate an .out file wish you can convert to txt file and read into excel.
Good luck!
press LIKE if this message was helpful
jps115 is offline   Reply With Quote
[General] Save unsteady data from a plane in Paraview rabz ParaView 1 September 27, 2020 03:16
How do I import tabular data from excel to ANSYS related to the geometry of a mesh? SteFanI Main CFD Forum 0 September 8, 2019 10:31
X Y PLOT - Save the data sidam STAR-CCM+ 3 July 9, 2013 08:35
Smallest binary file format to save large data Zonexo Main CFD Forum 2 June 2, 2008 20:25
Save User Data Ale Siemens 5 March 16, 2007 05:05
