Problem on succesive simulation runs and dpm file naming
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   March 23, 2022, 11:06
Default Problem on succesive simulation runs and dpm file naming
Fatih
fatihgulec is on a distinguished road
I try to run a transient particle simulation and sample particles at the outlet several times with a journal file as given below in Fluent. My final aim is to have several sample files (.dpm) at the end. To this end, I used the do-loop but I couldn't make it work. However, without using the do function, the code works fine for one simulation run.
I have two questions:
1) How can I make this code work? When I run this code, first I get the warning "Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed." on Fluent GUI and then "Error: eof inside list, Error Object: ()" in the console.
2) I want to change the dpm sample file which is generated automatically by Fluent, when I run the "/report/dpm-sample" command in the last row. How can I change the file name for each trial in the loop below? For example: outlet_1.dpm, outlet_2.dpm etc.,.. I looked through the TUI command list, but the commands to write a file are related with data case files.
Thank you in advance,
Journal File:
(define numbOfIterations 2); Define number of max. iterations per time step
(define delta_t 0.06); Define time step size [s]
(define no_t_s 2); Number of time steps
(do ((x1 1 (+ x1 1))) ((> x1 3)) ; define count - variable , start value and increment, define stop condition
/solve/initialize/initialize-flow y y ; do the Initialization, y y to discard the old data and clear history
/report/dpm-sample injection-0 injection-1 () outlet () () n n ; start sampling
/solve/set/time-step delta_t ; set the time step
/solve/dual-time-iterate no_t_s numbOfIterations; Perform unsteady iterations for a specified number of time steps
/report/dpm-sample );
fatihgulec is offline   Reply With Quote
Old   March 31, 2022, 22:36
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you have typo, you forgot bracket after do
code
personally I recommend you to use following format
(ti-menu-load-string (format #f "TUI COMMAND HERE"))
in that case all variables inside must be changed with ~a
example
(ti-menu-load-string (format #f "solve/set/time-step ~a" delta_t))
fatihgulec likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   April 4, 2022, 12:19
Fatih
code
example
Thank you for your answer. I added the parentheses for do but nothing changed. Should I use a scheme file instead of journal maybe?
Old   April 5, 2022, 01:50
Alexander
show code you are using, and log with errors
best regards
Old   April 5, 2022, 08:08
Fatih
The problem was not about the parantheses but about the commands in the do loop. So, I used the structure as you suggested (given below) and it works perfectly now. Thank you so much!
(define numbOfIterations 100); Define number of max. iterations per time step
(define no_t_s 150); Number of time steps
(define no_trial 50); Number of trials
(do ((x1 1 (+ x1 1))) ((> x1 no_trial))
	(ti-menu-load-string (format #f "/solve/initialize/initialize-flow y y")) ;Initialization, y y to discard the old data and clear history
	(ti-menu-load-string (format #f "/report/dpm-sample injection-0 injection-1 () outlet () () y n")) ; start sampling
	(ti-menu-load-string (format #f "/solve/set/time-step delta_t")) ; set the time step
	(ti-menu-load-string (format #f "/solve/dual-time-iterate no_t_s numbOfIterations")); Perform unsteady iterations for a specified number of time steps
	(ti-menu-load-string (format #f "/report/dpm-sample")); stop sampling
	( display x1)
But my second problem about dpm file naming still continues. I want to change the dpm sample file which is generated automatically by Fluent, when I run the "/report/dpm-sample" command in the last row. How can I change the file name for each trial in the loop below? For example: outlet_1.dpm, outlet_2.dpm etc.,.. I looked through the TUI command list, but the commands to write a file are related with data case files.
dpm in fluent, file name, journal file, loop
spray simulation with heat transfer using DPM Tensian Fluent Multiphase 1 June 7, 2016 04:57
