UDF for Defining different Density calculation formula for different Cell-zones.
Old   June 2, 2022, 12:20
Post UDF for Defining different Density calculation formula for different Cell-zones.
shubham
shubham is on a distinguished road
Hello all,
I have a problem in defining Density. I am simulating multiphase simulation where density is a function of Temperature and composition. For that I want to define two different density calculation formula in two different cell zones.
For this I am using the following UDF:
#include "udf.h"
#include "math.h"
#include "materials.h"
#include "threads.h"
/* I want to define two different DENSITY variation in two different cell zones. */
DEFINE_PROPERTY(cell_density,c,t)
real rho;
int i;
real T;
real xch4;
Material *sp;
Domain *mixture_domain;
mixture_domain = Get_Domain(3); // domain id of liquid phase = 3
Thread *tc1,*tc2;
tc1 = Lookup_Thread(mixture_domain,14); //14 is Domain id of bottom zone
tc2 = Lookup_Thread(mixture_domain,15); //15 Domain id of middle zone
if (t == tc1) //when thread pointer at bottom zone xch4 remain constant
mixture_species_loop(THREAD_MATERIAL(t),sp,i)
T = C_T(c,t);
xch4 = 0.89;
rho = (-0.8292 - (0.5407*xch4))*(T - 100) - (250.15*xch4) + 690.73;
//return rho;
else if (t == tc2) //when thread pointer at middle zone Temperature remain constant
T = 111.67;
xch4 = C_YI(c,t,1);
//return rho;
return rho;
The UDF compiles without any problems. However, as soon as it starts,
the simulation begins to diverge. Without UDF, the simulation runs without a hitch.
I can't seem to figure out what the issue is.
Does anyone have an idea what this can be due to?
Many thanks in advance.
shubham is offline   Reply With Quote
Old   June 10, 2022, 00:48
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
i think you don't need these lines:
most likely concentration macro leads to error
xch4 = C_YI(c,t,1);
it is possible, that at 0 moment concentration is not defined yet, but you are trying to use it for calculations, that will lead to problems if that is the case.
You may try to define some specific value for initialization (when time = 0) explicitly to bypass possible issue.
make sure you are using correct index for material either, which you put as 1
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
mixture density, multiphase mixture model, udf
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 07:21
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
UDF for current density in PEM fuel cell sajjad haider FLUENT 2 February 22, 2012 18:16
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
