Mass transfer boundary condition using two UDS (Drying process) |
June 14, 2022, 15:13 |
Hi everyone,
I'm trying to make a boundary condition in fluent to model the mass transport between a solid medium and the adjacent fluid (moist air) using 2 UDS (drying phenomenon). The first UDS represents the moisture content inside the solid (M -> mass of water / mass of solid) and the second UDS represents the mass fraction of water vapor in the fluid (Y -> mass of water vapor / mass of moist air). The equation for the boundary condition as well as an illustration are shown in the attached image. Γ0 and Γ1 are coefficients that are a function of the diffusivities and density of solid and fluid, respectively. Note that the variables M and Y are defined for different cell zone conditions and the face f delimits the boundary. Is there any way to adapt the functions BOUNDARY_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0) and BOUNDARY_SECONDARY_GRADIENT_SOURCE(source,n,dphi,d x,A_by_es,k) to solve UDS's Y and M simultaneously in the interface? Another function I thought to solve this problem was INTERIOR_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0,dr1 ). I don't know if it would fit because M and Y are defined in different cell zones. Also, there is no example in the UDF Manual using this function. Thank you in advance. |
July 23, 2023, 01:49 |
Mositure trasnfer from solid phase
Chhotelal
Rep Power: 2 |
have you solved this? I have the same query, In a two-phase problem, moisture is present in solid Xp, and other gas phases have some moisture content Xf. I don't understand how UDS scalar terms work, because two scaler terms are not added simultaneously, one is a solid phase and the other is a gas phase.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Solver for Multispecies Mass Transfer induced Domain growth/shrinkage | MonoC | OpenFOAM Running, Solving & CFD | 1 | March 13, 2016 07:41 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
