UDF and UDM or multiphase
Old   July 30, 2022, 08:52
Default UDF and UDM or multiphase
Rafau
rkadlof is on a distinguished road
Hi, I want to simulate interaction Moist Air with the stationary porous zone.
Moist air has its own concentration (Variable RH)
Packed bed has its own concentration (Variable REACT).
As the air flows through packed bed, decreases its RH. In a meanwhile packed bed increase its REACT and generates heat.
I need your help with approach how it can be done:
I thought about UDF with User scalars, where scalars RH and REACT are stored in moving air and stationary bed respectively.
Maybe it should be done with multiphase model?
If the approach with UDF and UDS/UDM would be possible, then how to write udf and get those custom scalar variables in UDF and change values?
Thank you for you time!
Rafa
rkadlof is offline   Reply With Quote
multiphase, udf
Contours of custom surface rate (UDF and UDM) cpassa FLUENT 2 August 14, 2021 13:25
UDF to store initial velocity components in UDM simonmcintyre FLUENT 0 August 15, 2018 05:06
Problem with interpreted UDF with UDM calculation Kabador FLUENT 4 July 8, 2018 03:36
Oddly diffuse results from UDF in multiphase (picture and udf) Jehosh Fluent UDF and Scheme Programming 2 February 11, 2016 04:53
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 09:01
