Enthalpy Calculation with UDF
Old   October 28, 2022, 03:49
Default Enthalpy Calculation with UDF
ANTALYA
erginbayrak is on a distinguished road
I have struggled to solve specific heat and enthalpy values of supercritical CO2 in the pipe using the following code (only for 80 bar). Although my code is running in Fluent, the solution does not converge. Also, there is a warning in Fluent as C4715: not all control paths return a value". I want to learn your recommendations about my problem. Regards,
#include "udf.h"
DEFINE_SPECIFIC_HEAT(supercritical_cp, T, Tref, h, yi)
   real cp;
    if (300. >= T)
               cp = 2.256999118844760E-02 * pow(T, 4.) - 2.606618818487370E+01 * pow(T, 3.) + 1.129129898467780E+04 * pow(T, 2.) - 2.174235523392760E+06 * T + 1.570278261279480E+08;
    if (306. >= T > 300.)
                cp = 1.147018354719330E+01 * pow(T, 4.) - 1.385519872072390E+04 * pow(T, 3.) + 6.276090044658930E+06 * pow(T, 2.) - 1.263530241490370E+09 * T + 9.539285116131690E+10;
    if (307.8 >= T > 306.)
                cp = -1.611612838918710E+04 * pow(T, 4.) + 1.978085636985280E+07 * pow(T, 3.) - 9.104578256081260E+09 * pow(T, 2.) + 1.862478067464320E+12 * T - 1.428738938943020E+14;
    if (310. >= T > 307.8)
                cp = -1.576135476848110E+03 * pow(T, 4.) + 1.945866130859760E+06 * pow(T, 3.) - 9.008641337104630E+08 * pow(T, 2.) + 1.853611584329810E+11 * T - 1.430227164258690E+13;
     if (320. >= T > 310.)
                cp = 1.770529718817220E+00 * pow(T, 4.) - 2.242833202341920E+03 * pow(T, 3.) + 1.065432793165650E+06 * pow(T, 2.) - 2.249454519629040E+08 * T + 1.781003821884030E+10;
      if (T > 320)
                cp = 2.086961941877520E-03 * pow(T, 4.) - 2.851496372954040E+00 * pow(T, 3.) + 1.461548345109060E+03 * pow(T, 2.) - 3.330816449664890E+05 * T + 2.848088978782360E+07;
   return cp;
#include<stdio.h>
float y(float T)
     if (300. >= T)
     return 2.256999118844760E-02 * pow(T, 4.) - 2.606618818487370E+01 * pow(T, 3.) + 1.129129898467780E+04 * pow(T, 2.) - 2.174235523392760E+06 * T + 1.570278261279480E+08;
     return 1.147018354719330E+01 * pow(T, 4.) - 1.385519872072390E+04 * pow(T, 3.) + 6.276090044658930E+06 * pow(T, 2.) - 1.263530241490370E+09 * T + 9.539285116131690E+10;
     return -1.611612838918710E+04 * pow(T, 4.) + 1.978085636985280E+07 * pow(T, 3.) - 9.104578256081260E+09 * pow(T, 2.) + 1.862478067464320E+12 * T - 1.428738938943020E+14;
     return -1.576135476848110E+03 * pow(T, 4.) + 1.945866130859760E+06 * pow(T, 3.) - 9.008641337104630E+08 * pow(T, 2.) + 1.853611584329810E+11 * T - 1.430227164258690E+13;
     return 1.770529718817220E+00 * pow(T, 4.) - 2.242833202341920E+03 * pow(T, 3.) + 1.065432793165650E+06 * pow(T, 2.) - 2.249454519629040E+08 * T + 1.781003821884030E+10;
      if (T > 320)
     return 2.086961941877520E-03 * pow(T, 4.) - 2.851496372954040E+00 * pow(T, 3.) + 1.461548345109060E+03 * pow(T, 2.) - 3.330816449664890E+05 * T + 2.848088978782360E+07;
// Function to evaluate the value of integral
        float trapezoidal(float Tref, float T, float n, float k, float *h)
        k = (T-Tref)/n;
        *h = y(Tref)+y(T);
         for (int i = 1; i < n; i++)
        *h += 2*y(Tref+i*k);
        return (k/2)*(*h);
        // Driver program to test above function
int main()
    // Range of definite integral (initial values)
     float T0 = 295;
    float Tn = 300;
    int n = 2000;
    return 0;
erginbayrak is offline   Reply With Quote
Old   November 2, 2022, 23:00
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
first of all this is your code
#include "udf.h"
   real cp;
    if (300. >= T)
      if (T > 320)
   return cp;
remove everything below ( starting from #include<stdio.h> )
second point here is your condition sequence:
(300. >= T) will always be true, so only first equation would be executed, also Cp is not specified at temperature below 300
-> go from top bottom
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 3, 2022, 03:17
ANTALYA
Thank you for your reply. I couldn't understand the logic of the sequence. Is it important for initialization? I have just tried it by obeying your advice, but I take some invalid cp errors (I checked the invalid cp errors at related temperatures by hand, and there is no problem with my equation). My other question is that the calculation of the enthalpy value. According to the manual, we must describe the equation of enthalpy. In my case, it should be integration from Tref to T, shouldn't it?
So, my new code:
#include "udf.h"
   real cp;
 if (T > 320.)
                *h = (2.086961941877520E-03 / 5.) * (pow(T, 5.) - pow(Tref, 5.)) - (2.851496372954040E+00 / 4.) * (pow(T, 4.) - pow(Tref, 4.)) + (1.461548345109060E+03 / 3.) * (pow(T, 3.) - pow(Tref, 3.)) - (3.330816449664890E+05 / 2.) * (pow(T, 2.) - pow(Tref, 2.)) + 2.848088978782360E+07 * (T-Tref);
               *h = (1.770529718817220E+00 / 5.) * (pow(T, 5.) - pow(Tref, 5.)) - (2.242833202341920E+03 / 4.) * (pow(T, 4.) - pow(Tref, 4.)) + (1.065432793165650E+06 / 3.) * (pow(T, 3.) - pow(Tref, 3.)) - (2.249454519629040E+08 / 2.) * (pow(T, 2.) - pow(Tref, 2.)) + 1.781003821884030E+10 * (T-Tref);
                *h = (-1.576135476848110E+03 / 5.) * (pow(T, 5.) - pow(Tref, 5.)) + (1.945866130859760E+06 / 4.) * (pow(T, 4.) - pow(Tref, 4.)) -  (9.008641337104630E+08 / 3.) * (pow(T, 3.) - pow(Tref, 3.)) + (1.853611584329810E+11 / 2.) * (pow(T, 2.) - pow(Tref, 2.)) - 1.430227164258690E+13 * (T-Tref);
                 *h = (-1.611612838918710E+04 / 5.) * (pow(T, 5.) - pow(Tref, 5.)) + (1.978085636985280E+07 / 4.) * (pow(T, 4.) - pow(Tref, 4.)) - (9.104578256081260E+09 / 3.) * (pow(T, 3.) - pow(Tref, 3.)) + (1.862478067464320E+12 / 2.) * (pow(T, 2.) - pow(Tref, 2.)) - 1.428738938943020E+14 * (T-Tref);
                *h = (1.147018354719330E+01 / 5.) * (pow(T, 5.) - pow(Tref, 5.)) - (1.385519872072390E+04 / 4.) * (pow(T, 4.) - pow(Tref, 4.)) + (6.276090044658930E+06 / 3.) * (pow(T, 3.) - pow(Tref, 3.)) - (1.263530241490370E+09 / 2.) * (pow(T, 2.) - pow(Tref, 2.)) + 9.539285116131690E+10 * (T-Tref);
 if (300. >= T)
               *h = (2.256999118844760E-02 / 5.) * (pow(T, 5.) - pow(Tref, 5.))- (2.606618818487370E+01 / 4.) * (pow(T, 4.) - pow(Tref, 4.)) + (1.129129898467780E+04 / 3.) * (pow(T, 3.) - pow(Tref, 3.)) - (2.174235523392760E+06 / 2.) * (pow(T, 2.) - pow(Tref, 2.)) + 1.570278261279480E+08 * (T-Tref);
   return cp;
Old   November 3, 2022, 03:19
ANTALYA
#include "udf.h"
   real cp;
    if (300. >= T)
      if (T > 320)
   return cp;
So, my new code:
#include "udf.h"
   real cp;
 if (T > 320.)
 if (300. >= T)
   return cp;
Old   November 4, 2022, 03:56
ANTALYA
My following code is compiling very well, but I have some convergence problems. There is divergence detected and floating point exception warnings. If I decrease the URF of the energy equation, iteration starts, but I take some errors after a certain iteration again. This situation didn't change although used a finer mesh structure. I am continuing to study on it. Any comments or suggestions are welcome. Regards. EB
My revised code is as follows:
#include "udf.h"
   real cp;
 if (T > 320.)
 else if (320. >= T > 310.)
 else if (310. >= T > 307.8)
 else if (307.8 >= T > 306.)
 else if (306. >= T > 300.)
 else
   return cp;
i have a problem with my udf when I give it Run Calculation secorreaz Fluent UDF and Scheme Programming 1 April 3, 2022 22:57
UDF For inlet Velo BC, trouble in soln calculation Siddharth17 Fluent UDF and Scheme Programming 2 March 24, 2022 08:08
Enthalpy Calculation for every media Component MNMK CFX 0 May 3, 2021 03:58
Define_Source UDF for Enthalpy of Dilution jreiter164 Fluent UDF and Scheme Programming 4 March 18, 2015 20:10
my UDF can not calculation? happyrabbit FLUENT 0 October 21, 2010 08:59
