Why temperature dependent UDF is crashing in Ansys fluent without any error?
Old   November 6, 2022, 00:04
Default Why temperature dependent UDF is crashing in Ansys fluent without any error?
Ram Rapaka
RamR is on a distinguished road
In am using a UDF for heat flux that is dependent on temperature. If I am using constant temperature it is giving results. But using temperature function (F_T(f,t)) in code, fluent is crashing withot any error while initiation. I am attaching my code.Untitled.png
#include "udf.h"
#include "math.h"
DEFINE_PROFILE(heat_profile_pinbase,thread,positio n)
real x[ND_ND];
real a,b,c,r;
//sticking and slipping heat flux
real stk,slp;
// Fractional plastic deformation converted to heat and percentage of heat transfered to w/p
real eta_m = 0.4, eta_h=0.6;
// Fractional slip and coefficient of friction
real delta, mu_f;
// Fitting Constant
real C_f = 0.31;
// Angular Velocity, welding speed and Axial Pressure
real omg = 157.08, U = 0.0017, P_n=10*pow(10,6);
// Yield Stength and shear strength
//real sig_y = 50 * pow(10,6), tou_y = sig_y / sqrt(3);
real sig_y,tou_y;
// Axial center coordinates
int i=0,j=0,k=0;
real tem;
face_t f;
//cell_t ce;
begin_f_loop(f,thread)
//tem = 300;
tem = F_T(f,thread);
//tem = C_T(ce,thread);
if (tem >= 800)
tou_y = 0;
else
sig_y = (11.76 + 8206.07 / exp(tem / 107.60)) * pow(10, 6);
F_CENTROID(x,f,thread);
a =x[0]-i;
b =x[1]-j;
c =x[2]-k;
// radial distance
r =sqrt(pow(a,2)+pow(c,2));
//Fractinal slip and co-efficient of friction
delta = C_f * exp((r * omg) / 1.87) - 0.026;
mu_f = 0.5 / exp(delta * r * omg);
// Sticking and Sliping heat flux
stk= eta_m *(1-delta)*tou_y;
slp=delta*mu_f*P_n;
//Total Heat Flux
F_PROFILE(f,thread,position) = eta_h *(stk+slp)*(omg*r-U*(a/r));
end_f_loop(f,thread)
RamR is offline   Reply With Quote
Old   November 8, 2022, 23:36
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
where is F_T(f,t) macro in your code?
fluent is not crushing without errors if:
1. UDF is compiled properly
2. Fluent is installed properly
in other words, compile your udf, fix all errors and run case. If fluent crashes still, reinstall fluent
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 9, 2022, 01:22
Ram Rapaka
I have highlighted (tem = F_T(f,thread)) micros in the code. Thank you
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
