How to calculate dissipation rate in FLUENT via UDF
Old   April 17, 2023, 13:34
Default How to calculate dissipation rate in FLUENT via UDF
hasan
hsncnr is on a distinguished road
Hi;
I want to calculate the dissipation rate in Fluent using user define function. But I am receiving below error. My UDF code is below. what is the solution for this error? thanks a lot.
Error
''BAD TERMINATION OF ONE OF YOUR APPLICATION PRECESSS
RANK 3 PID 5800 RUNNING AT DESKTOP''
UDF
#include "udf.h"
#include "mem.h"
DEFINE_SOURCE (new_source, c, t, ds, eqn)
real source;
source= 0.001*pow(C_D(c,t) ,4.6);
ds[eqn] = 0.;
return source;
hsncnr is offline   Reply With Quote
Old   May 15, 2023, 12:43
Odisha
Siba11 is on a distinguished road
Hi, the ds[eqn] term will be the derivative of the source term. In your case, it won't be zero.
Siba11 is offline   Reply With Quote
Old   May 19, 2023, 12:35
hasan
Thank you for your reply. can ANSYS calculate the derivative of turbulence kinetic energy? I cannot find it in the ANSYS user manual. Here, C_D(c,t) is turbulence kinetic energy.
Old   May 19, 2023, 12:59
Odisha
Hi. You don't have to calculate the derivative of C_D(c,t). You have to calculate the derivative w.r.t C_D(c,t).
Basically, you're derivative term will be:
ds[eqn] = 0.001*4.6*pow(C_D(c,t), 3.6);
Old   May 23, 2023, 02:58
hasan
Although I added to the derivation express, I get the following error.
BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
RANK 0 PID 6920 RUNNONG AT DESKTOP-
EXIT STATUS:-1 (fffffffff)
How to calculate dissipation rate in OpenFOAM farzadmech OpenFOAM Post-Processing 4 November 24, 2022 02:20
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 02:48
UDF to access interior surface to calculate mass flow rate shahjehan Fluent UDF and Scheme Programming 0 August 11, 2015 14:44
How to calculate Sherwood number by UDF in Fluent for double-diffusion study xjtuxht Fluent UDF and Scheme Programming 0 May 2, 2013 20:21
How to calculate the mass flow rate with UDF ? HP FLUENT 0 January 10, 2005 19:38
