Writing UDF using Input Parameters
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   July 3, 2023, 09:49
Lightbulb Writing UDF using Input Parameters
alik91en is on a distinguished road
Hello everyone
I want to define the specific heat based on the input parameter from workbench. It is not Temperature dependent, it is only based on the input parameter I've defined in Workbench Parameters (phi)
Should I write a udf for it? Does anyone know how to write it?
alik91en is offline   Reply With Quote
Old   July 11, 2023, 04:33
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may get parameter value using
Get_Input_Parameter("variablename")
Returns the input parameter value of variable-name
for more details check ansys fluent customization manual / google
alik91en likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 20, 2023, 02:13
Default DEFINE_GRID_MOTION UDF code
Naren
Narendhiran_IIT_Madras is on a distinguished road
Hi
How to use DEFINE_GRID_MOTION UDF code to prescribe dynamic mesh motion in ansys fluent?
Narendhiran_IIT_Madras is offline   Reply With Quote
fluent, parameters, udf, workbench
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 18:28
Can you check my code of writing UDF? THA SEANGHAI FLUENT 5 August 13, 2020 02:24
Sutile and Tricky : Drive Fluent UDF parameters directly from workbench amscosta Fluent UDF and Scheme Programming 4 July 21, 2020 16:50
Tutorial for running ANSYS/Fluent with continuous input parameters chaitanya.mokashi FLUENT 0 April 20, 2017 19:41
Add new particle force with input parameters ycui OpenFOAM Running, Solving & CFD 5 March 22, 2017 11:46
