July 10, 2023, 23:15 |
Problem with mhd udf
niming
Rep Power: 2 |
I plan to use fluent to do a simulation of magnetic fluid power generation, which needs to be written through udf, but there is no reference file, so I can't write it. Can someone please give me some guidance?
Thank you!!! |
July 11, 2023, 04:52 |
Alexander
Rep Power: 34 |
search for published papers regarding this topic.
you may need to control momentum and sources through UDF read ansys fluent customization manual
best regards ****************************** press LIKE if this message was helpful |
July 11, 2023, 04:58 |
niming
Rep Power: 2 |
Thank you. I have also read related papers to add Lorenz force source term to momentum equation and Joule heat source term to energy equation, but I am not sure how to write the corresponding udf
July 22, 2023, 13:52 |
Source UDF?
Thamilmani M
Rep Power: 8 |
This is what I have been doing for modelling source terms. So, I hope this helps.
1. First Find any DEFINE_SOURCE () example UDF from UDF Manual and see if you can properly compile and load it just to learn how to work with UDFs. 2. Once your source term is known from your literature, break them down into variables that are accessible from the UDF Data access macros. 3. If the source term contains gradients of inaccessible variables, Set the variable up as UDS (through DEFINE_ADJUST) and access its gradient from UDSI_G.
Always Thedal |
July 23, 2023, 02:35 |
#5 | |
niming
Rep Power: 2 |
fluent, mhd, udf |
Problem with MHD module and writing the UDF | aminrahmat | Fluent UDF and Scheme Programming | 5 | March 2, 2020 07:33 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
udf loading problem | santu | Fluent UDF and Scheme Programming | 1 | May 22, 2015 15:47 |
Vaporization pressure UDF property problem? | lehoanganh07 | Fluent UDF and Scheme Programming | 1 | September 13, 2014 10:59 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 06:56 |
