How fluent solver work inside the fluent?
Old   July 28, 2023, 07:27
Default How fluent solver work inside the fluent?
Chhotelal
Chhotelal1234 is on a distinguished road
I want to know, how Fluent Solver takes the variable and calculates the value when uploading the UDF function.
In a simple case, I upload only the DEFINE INIT function and initialized the problem, the value is not getting the true value.
#include "udf.h"
#define M 0.25
#define RHO 1600
#define E 0.4
#define Tref 300
#define Tin 300
int last_timestep = -1;
DEFINE_INIT(initial_humidity, d)
real Tabs, w, a, b, C, Pvs, RH;
Thread *t;
cell_t c;
thread_loop_c(t, d)
begin_c_loop(c, t)
C_T(c, t) = Tin;
Tabs = C_T(c, t);
Pvs = 0.1 * exp(27.0214 - (6887 / Tabs) - (5.31 * log(Tabs / 273.16))); /* Eq(25) */
b = 2.667e-7 * pow((1 - (Tabs / 641.7)), -23.438);
C = 1 / (4e5 * pow(Tabs, -2.1166));
a = b * pow(1000 * M, 1 / C);
RH = 1 - exp(-a / Tabs); /* Eq (15) */
if (RH > 0.99)
RH = 0.99;
w = (Pvs * RH * 0.62189) / (101.3 - Pvs * RH); /* Eq (26) */
end_c_loop(c, t)
Message ("realative humidity:%f\n", w);
Message ("Pv:%f\n", Pvs);
Message ("RH:%f\n", RH);
Error is coming, and the value getting Zero at the initial condition
initial_humidity
Done.
realative humidity:0.000000
Pv:0.000000
RH:0.000000
Node 10: Process 22992: Received signal SIGSEGV.
Chhotelal1234 is offline   Reply With Quote
Old   July 30, 2023, 06:13
thedal's Avatar
Thamilmani M
thedal is on a distinguished road
Which variable are you trying to initialize here?
You are initializing temperature as Tin and calling C_T again to calculate some function. Why?
Always
Thedal
thedal is offline   Reply With Quote
Old   July 30, 2023, 06:20
thedal's Avatar
Thamilmani M
Also try
begin_c_loop_all(c, t) instead and check what happens.
DEFINE_INIT is executed only once during initialization.
Always
Thedal
Old   July 30, 2023, 06:32
thedal's Avatar
Thamilmani M
I think the formulation is correct. only problem could be with the begin_c_loop(c, t)
Always
Thedal
Old   July 30, 2023, 07:46
Chhotelal
I want to initialize the relative humidity value here. I do the same thing to replace by begin_c_loop_all(c, t) but the same error is coming
relative humidity:0.000000
Pv:0.000000
RH:0.000000
Node 5: Process 27536: Received signal SIGSEGV.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 10 PID 21372 RUNNING AT DESKTOP-MGARH2C
= EXIT STATUS: -1 (ffffffff)
The fl process could not be started.
Old   July 30, 2023, 08:19
Chhotelal
This may occur by not defining the allocating memory. it might be right.
alexanderz
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
Selection of solver in ANSYS Fluent for given mach number Ankit Patel FLUENT 9 January 29, 2021 04:44
Fluent Adjoint Solver for compressible flow b.shuvayan FLUENT 2 January 30, 2015 07:27
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 06:53
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
