define_profile and F_UDMI
Like Tree1Likes
  • 1 Post By pakk
Old   April 14, 2015, 10:02
Default define_profile and F_UDMI
philus is on a distinguished road
Hi all,
I am trying to set a particular wall heat transfer coefficient to an external wall. I also wanted to monitor the value computed by my UDF, then I used the user-defined memory. But the correspondent variable (when I search for it in FLuent) is always zero. Note that if I write in the UDF printf('variable name') I get the good values....but I need to put these values into a variable!
I copy paste the simplified UDF:
DEFINE_PROFILE(name,t,i)
  real h;
  begin_f_loop(f,t){
    h=10.0;
    F_UDMI(f,t,0) = h;
    printf("h:%f\n",h);
    F_PROFILE(f,t,i)= h;
  end_f_loop(f,t)
I have the impression that the UDF works well for setting the boundary condition (the results that I obtain from the simulation corresponds to what I was expecting), but I cannot monitor the variable (h) that I have created: the corresponding User Defined Memory variable (User Memory 0) is always nil.
Can someone explain me what is the problem?
Thanks in advance
philus
philus is offline   Reply With Quote
Old   April 14, 2015, 10:57
pakk will become famous soon enough
I have seen this behavior too. The UDM stored with F_UDMI did not show up in my Fluent results. I don't know if this is intended or a bug, but I found a workaround that worked for me:
F_UDMI(f,t,0) = h;
C_UDMI(F_C0(f,t),THREAD_T0(t),0) = F_UDMI(f,t,0);
hos128 likes this.
pakk is offline   Reply With Quote
Old   April 15, 2015, 04:56
Hi pakk,
effectively this workaround works well, thank you!!
philus
Old   November 5, 2023, 07:46
anonymous96
anonymous96_ is on a distinguished road
Hi Pakk
I am trying to calculate volumetric flow rate through an interior surface and using DEFINE_ON_DEMAND macro for the same. A piece of my code is as follows:
DEFINE_ON_DEMAND(ach_udf)
Thread *t;
face_t f;
Domain *d;
real A[ND_ND];
real ACHt_mean_out=0;
real ACHt_mean_in=0;
t = Lookup_Thread(d,2);
begin_f_loop(f,t)
F_AREA(A,f,t);
real vel_roof= F_FLUX(f,t)/(NV_MAG(A)*1.12);
if (vel_roof>0)
ACHt_mean_out += vel_roof*NV_MAG(A);
else
ACHt_mean_in +=vel_roof*NV_MAG(A);
end_f_loop(f,t)
The code is compiled successfully but as soon as I am executing it using EXECUTE_ON_DEMAND, it is giving the following error:
Node 1: Process 20248: Received signal SIGSEGV.
Node 999999: Process 6872: Received signal SIGSEGV.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 2 PID 4296 RUNNING AT DESKTOP-PA0EM1I
= EXIT STATUS: -1 (ffffffff)
Can anyone tell how to fix this?
anonymous96_ is offline   Reply With Quote
Old   November 6, 2023, 04:31
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
d is not defined
compile code and READ log to avoid typoes
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 6, 2023, 05:11
anonymous96
Thankyou Alexander. If figured that out but I am getting stuck at one more point. I have posted in another thread and you are a part of it too. Can you please look into it.
Old   November 6, 2023, 05:16
anonymous96
UDF - C_UDMI is giving sigsegv error
Can you please look into it Alexander?
