June 24, 2003, 09:59 |
hook a compiled DEFINE_ADJUST UDF to FLUENT
Hi everybody I wrote a DEFINE_ADJUST UDF that prints face centroid coordinates of a wall zone, but after I compiled it, it doesn't appear in the "Adjust function" drop-down list of the Define -> User-Defined -> Function Hooks...PANEL!!! could anyone tell me why ? thanx!
June 25, 2003, 04:59 |
Re: hook a compiled DEFINE_ADJUST UDF to FLUENT
did you load the UDF library into fluent after complining it. can do this by typing def, user, comp, l and then the directory of your UDF library, e.g. libudf
June 25, 2003, 07:24 |
Hi Andrew ! yes I did, and it loads normally. I tried to hook it from the text command mode: Define/User-Defined/Function-Hooks...but still doesn't work!! it gives me the error message: ******************************* *Error: eval: unbound variable *Error Object: myUDF.c *Invalid string. ******************************** and still doesn't appear in the drop down list. I tried to initialize before...that doesn't change anything.
December 14, 2012, 03:08 |
Jaime Rowelt
Rep Power: 13 |
Hi! I have exactly the same problem. Everything works fine, but in the window "User-Defined Function Hooks" nothing appears...and cause of this I canīt save the dynamic results...
I donīt know what means this problem. I sospite itīs due to the way I define my UDF. Please ideas/help!! |
Fluent UDF Discontinuous Motion | lequi7 | Fluent UDF and Scheme Programming | 2 | November 3, 2011 23:18 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 10:16 |
UDF of Zimont model in fluent | Z | Main CFD Forum | 0 | February 17, 2005 03:07 |
UDF in parallel version of fluent | yobee | FLUENT | 2 | August 5, 2004 00:36 |
how to quit compiled or interprited UDF | tian | FLUENT | 0 | April 8, 2003 23:53 |
