Error compile file udf
Old   June 17, 2009, 05:34
Default Error compile file udf
czfluent is on a distinguished road
Hi everybody
I have problem with compile udf in Windows XP x64bit.
I compiled and used a UDF succesfully on Linux, but it fails to compile on Windows. So Iīm using Fluent version Fluent-ntx86-6.3.26.
This is my file whose I need compile:
http://rapidshare.com/files/245477895/manualUDFexmaple_2.3.27__ex1_.c.html
And here is error messages from Fluent:
Could you please somebody help or tell me what I need for right compile.
PS:sorry my english is bad
czfluent is offline   Reply With Quote
Old   June 17, 2009, 07:54
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
What compiler do you use ? you need a 32 bits compiler with fluent ntx86.
laurentb is offline   Reply With Quote
Old   June 17, 2009, 08:50
Iīm try to use windows c sdk ... but I donīt know how itīs working ... please could you send me step by step how to compile ?
Old   June 17, 2009, 09:25
laurentb's Avatar
Laurent B
See instructions in the pdf file attached
Microsoft C++
2008 Express Edition
which can be located at this link:
http://www.microsoft.com/downloads/d...DisplayLang=en
Old   June 18, 2009, 17:11
I have still same problem ...
Old   June 18, 2009, 23:22
los
Tiago Macarios
los is on a distinguished road
I ask myself why would you use a 32 bits fluent in a 64 bits environment...
Anyway it looks like you compiler is not set in the system path, that's why fluent cannot find it.
Try to concatenate you compiler directory at the system path, if it doesn't work, I think that Visual studio 2008 professional can compile 32 bits too, why don't you give it a try?
los is offline   Reply With Quote
Old   June 19, 2009, 02:31
so now Iīm using fluent 6.3.26 with Windows XP 32b. What does you mean concatenate system path with compiler directory My system path for fluent:
C:\Program Files\Fluent.Inc
and
C:\Program Files\Microsoft Visual Studio 9.0\VC\
"Microsoft Visual Studio 2008
Version 9.0.30729.1 SP
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: VC Express
Microsoft Visual C++ 2008 91909-152-0000052-60589
Where I can compile file in Microsoft Visual C++ 2008
Iīm try to use Interpreted UDFs from Fluent:
cpp -I"C:\PROGRA~1\Fluent.Inc\fluent6.3.26/src" -I"C:\PROGRA~1\Fluent.Inc\fluent6.3.26/cortex/src" -I"C:\PROGRA~1\Fluent.Inc\fluent6.3.26/client/src" -I"C:\PROGRA~1\Fluent.Inc\fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "C:\working\man
alUDFexmaple_2.3.27_[ex1].c"
Error: C:\working\manualUDFexmaple_2.3.27_[ex1].c: line 51: structure reference not implemented
Old   June 23, 2009, 02:40
Could you help me please, anyone?
When I try to load my case and data Fleunt answer me:
Building...
grid,
Cell Centroid is xc 3.733333 yc 0.200000
WARNING: no face with given nodes. Thread 2, cell 9
Error: Build_Grid: grid error.
Clearing partially read grid.
Error: Null Domain Pointer
Error Object: ()
But the other PC working ... maybe wrong install ?
Old   July 7, 2009, 16:02
so now I know why the FlUENT write me:
Building...
grid,
Error Object: ()
I have a bad case data and files ... but still compile donīt working ...
Old   July 8, 2009, 16:21
SK
friends.sk is on a distinguished road
Please Start Fluent from c++ command prompt.
It should work. best wishes.
friends.sk is offline   Reply With Quote
Old   July 26, 2009, 15:09
but, how to do that? please some screen? thank you!
Old   July 30, 2009, 03:59
laurentb's Avatar
Laurent B
print screen : visual c++ command prompt
then launch fluent, for example :
C:\Fluent.Inc\ntbin\ntx86\fluent.exe -r6.3.26
Old   July 31, 2009, 01:54
ok thank itīs working but ...
The system have not find this file ... or something like this write me fluent -...
(system "copy C:\PROGRA~1\Fluent.Inc\fluent6.3.26\src\makefile_n t.udf libudf\ntx86\2ddp\makefile")
1 copy file …
(chdir "libudf")()
(chdir "ntx86\2ddp")()
Done.
"c:/"
Opening library "libudf"...
Error: open_udf_library: The system have not find this file ...
Error Object: ()
Old   August 18, 2009, 07:10
matth
dahu007 is on a distinguished road
Did you find a solution ? I have the same problem with visual C++ 2008 express !
dahu007 is offline   Reply With Quote
Old   August 21, 2009, 04:06
No, I have still problem with error ...
Please could you anyone help me ad my dahu007 ?
Old   August 21, 2009, 04:26
SK
I think your udf file is not in the same directory as your cas and data file. Pls. Check
Old   August 21, 2009, 05:04
No I have ... look
Old   August 21, 2009, 05:12
matth
I reinstaled Microsoft visual C++ and Nox it works !!
Old   August 21, 2009, 07:02
yes, me tooĻ.. still same problem ...
Old   August 22, 2009, 15:31
matth
when I instaled Microsoft visual C++ I picked all the option. You have to install microsoft.net framework 3.5 ans above all the msdn library !
Good luck !
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 14:30
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
UDF source file zhou FLUENT 3 September 29, 2003 11:53
