Do I need to use UDF to get time-averaged variable?
Old   August 11, 2009, 14:26
Default Do I need to use UDF to get time-averaged variable?
Ivan
ivanbuz is on a distinguished road
I am using LES model to simulate turbulent flow around an airfoil, and want to get the time-averaged pressure coefficient of the airfoil. I have done some research and it seems that UDF is the only way to do it. Can anyone confirm this and give some advice about which macros to use?
If anyone have a UDF that computes a time-averaged variable, can you post it here as an example if you don’t mind?
I appreciate your help and thank you for your time!
ivanbuz is offline   Reply With Quote
time average, udf
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
ADAMS-BASHFORD w/ VARIABLE TIME STEP IRFAN Main CFD Forum 0 July 28, 2005 13:14
