September 20, 2009, 00:15 |
UDF interpret error with "C_CENTROID"
Jinfeng
Hi folks,
I wrote a program to calculate the electrical body force with DEFINE_SOURCE macro. Inside the macro, C_CENTROID was used to get the coordinates of the cells (just like the DEFINE_SOURCE example in UDF manual). However, when I try to interpret the code, it gives me an error saying "line 13 C_CENTROID undeclared variable." I can't figure out why it threw me that error! Does anybody know what's going on? Any help would be greatly appreciated! Thanks. The following code is the DEFINE_SOURCE part: #include "udf.h" DEFINE_SOURCE(xmom_source, c, t, dS, eqn) { int i; // index for the nodes float startx; // x coordinate of nearest node to interpolation node with lower x value float starty; // y coordinate of nearest node to interpolation node with lower y value float startz; // z coordinate of nearest node to interpolation node with lower z value float xinterpfact, yinterpfact, zinterpfact; float newrho; float newdvdx, newdvdy, newdvdz; float xinterp1, xinterp2, xinterp3, xinterp4; float yinterp1, yinterp2; real x[ND_ND]; real source; C_CENTRIOD(x,c,t); xinc = xdomain/(xdirnodes-1); yinc = ydomain/(ydirnodes-1); zinc = zdomain/(zdirnodes-1); startx = ((int)(x[0]/xinc))*xinc; xinterpfact = (x[0] - startx)/xinc; starty = ((int)(x[1]/yinc))*yinc; yinterpfact = (x[1] - starty)/yinc; startz = ((int)(x[2]/zinc))*zinc; zinterpfact = (x[2] - startz)/zinc; i = xdirnodes*ydirnodes*startz/zinc + xdirnodes*starty/yinc + startx/xinc; //*** INTERPOLATE RHO ***// xinterp1 = xinterpfact*(rho[i+1]-rho[i]) + rho[i]; xinterp2 = xinterpfact*(rho[i+xdirnodes+1]-rho[i+xdirnodes])+rho[i+xdirnodes]; xinterp3 = xinterpfact*(rho[i+xdirnodes*ydirnodes+1]-rho[i+xdirnodes*ydirnodes])+rho[i+xdirnodes*ydirnodes]; xinterp4 = xinterpfact*(rho[i+xdirnodes+xdirnodes*ydirnodes+1]-rho[i+xdirnodes+xdirnodes*ydirnodes])+rho[i+xdirnodes+xdirnodes*ydirnodes]; yinterp1 = yinterpfact*(xinterp2-xinterp1)+xinterp1; yinterp2 = yinterpfact*(xinterp4-xinterp3)+xinterp3; newrho = zinterpfact*(yinterp2-yinterp1)+yinterp1; //*** INTERPOLATE DVDX ***// xinterp1 = xinterpfact*(dvdx[i+1]-dvdx[i]) + dvdx[i]; xinterp2 = xinterpfact*(dvdx[i+xdirnodes+1]-dvdx[i+xdirnodes])+dvdx[i+xdirnodes]; xinterp3 = xinterpfact*(dvdx[i+xdirnodes*ydirnodes+1]-dvdx[i+xdirnodes*ydirnodes])+dvdx[i+xdirnodes*ydirnodes]; xinterp4 = xinterpfact*(dvdx[i+xdirnodes+xdirnodes*ydirnodes+1]-dvdx[i+xdirnodes+xdirnodes*ydirnodes])+dvdx[i+xdirnodes+xdirnodes*ydirnodes]; yinterp1 = yinterpfact*(xinterp2-xinterp1)+xinterp1; yinterp2 = yinterpfact*(xinterp4-xinterp3)+xinterp3; newdvdx = zinterpfact*(yinterp2-yinterp1)+yinterp1; source = newrho*newdvdx; dS[eqn] = 0.0; return source; } Last edited by Jinfeng; September 20, 2009 at 15:22. |
September 20, 2009, 05:16 |
Bernhard
Rep Power: 21 |
It will help when you show the relevant part of your UDF. Now I can only guess for possible errors in your code.
September 25, 2009, 10:55 |
Akour
you have spelt C_CENTROID incorrectly...youve got C_CENTRIOD.
akour |
September 26, 2009, 17:40 |
Jinfeng
November 5, 2020, 10:02 |
abdo
Rep Power: 7 |
this is my udf:
#include "udf.h" #include "mem.h" #define Y_CH4_in 0.032 #define Y_O2_in 0.225 DEFINE_PROFILE(mass_fraction, t, i) { face_t f; begin_f_loop(f, t) { F_CENTROID(x, f, t); F_PROFILE(f, t, i) = Y_CH4_in; F_PROFILE(f, t, i) = Y_O2_in; } end_f_loop(f, t) } |
November 6, 2020, 06:33 |
Rep Power: 26 |
Interesting code, I see that it is still the same as several days ago, so the same problems are there. If you don't understand suggestions, ask for clarification, don't just ignore the help you get and ask the question again...
November 6, 2020, 15:38 |
abdo
Rep Power: 7 |
Hello, I correct some error and it compile but there are other error related to the temperature that why I repulish the new one.I can't change the concentrations of each species.
Can not to interpret UDF | AlexanderSventitskiy | FLUENT | 4 | August 18, 2011 08:10 |
interpret or compile an UDF (emergency) | Lotfi | FLUENT | 1 | August 26, 2007 12:58 |
Not able to interpret UDF | Prasad | FLUENT | 1 | August 15, 2007 08:44 |
Interpret three UDF for property | Atsu | FLUENT | 4 | April 22, 2006 15:04 |
UDF Interpret - Syntax Error | Leonard | FLUENT | 1 | October 22, 2005 10:06 |
