energy source problem
Old   January 7, 2010, 11:19
Default energy source problem
nickeet
fluboy is on a distinguished road
Dear All
I am a beginner in UDF
I need to set a energy source in a solid (W/m3)
And the energy source is temperature dependent
I got this error message:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save cas/data under new name.
3. Exit programme and restart to continue.
4. Report error to your distributor.
Error object
My UDF is as follow
#include "udf.h"
DEFINE_SOURCE(energy_source, c, t, dS, eqn)
real temp;
real source;
temp = C_W(c,t);
if (temp<293 && temp>290)
source = 1000.;
else
source = 0.;
return source;
pls give me some direction and suggestion.
Thanks.
fluboy is offline   Reply With Quote
Old   January 8, 2010, 03:36
Max
coglione is on a distinguished road
C_W(c,t) will return the z-velocity which does not make too much sense for a solid. Maybe C_T(c,t) is what you actually want to use.
cheers
coglione is offline   Reply With Quote
Old   January 10, 2010, 08:56
nickeet
Thank you, coglione
I will try it!!
UDF for energy source term Muhammad Aamir Khan FLUENT 1 July 25, 2007 02:08
energy source Universtiy Paul FLUENT 3 April 21, 2006 15:15
Energy Source Help! Andrew Clark FLUENT 1 October 24, 2005 14:39
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
