Case filename variable
Old   May 12, 2010, 16:13
Default Case filename variable
eshimshi is on a distinguished road
Is there a variable containing the name and path of the current loaded case?
Can it be retrived by UDF or scheme?
Thanks
eshimshi is offline   Reply With Quote
Old   May 13, 2010, 02:35
gearboy is on a distinguished road
Thanks
Scheme to get the full-path case name:
(in-package cl-file-package rc-filename)
Scheme to get the case name:
(strip-directory (in-package cl-file-package rc-filename))
If you want to use them in UDF, just use CX_Interpret_String command to let them recognized by UDF. i.e.,
CX_Interpret_String("(in-package cl-file-package rc-filename)");
CX_Interpret_String("(strip-directory (in-package cl-file-package rc-filename))");
gearboy is offline   Reply With Quote
Old   May 13, 2010, 02:45
scheme just get the path:
(directory (in-package cl-file-package rc-filename))
Old   May 14, 2010, 07:38
Thumbs up
Thanks for the help,
Old   May 14, 2010, 08:17
it woks fine for scheme but in the UDF i get an Unbound variable erorr.
Do I have to add some #include file?
Old   May 17, 2010, 00:46
It seems that the CX_Interpret_String can't Interpret in-package command.
Another choice:
write the scheme command in a scm file, e.g. D:\test.scm. Write two commands in it.
(if(not(rp-var-object 'file-name))(rp-var-define 'file-name "" 'string #f) "")
(rpsetvar 'file-name (in-package cl-file-package rc-filename))
Then in your UDF code.
char*FileName;
CX_Interpret_String("(ti-read-scheme \"D:\\test.scm\")");
FileName=RP_Get_String("file-name");
Message0("Current case name is %s\n",FileName);
journal file with variable in a while loop? Ralf Schmidt FLUENT 50 January 17, 2019 05:24
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 08:19
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
