June 3, 2010, 09:03 |
mass flow rate inlet udf
ali
i have a case in which mass flow rate increases for 0.5 sec.
anybody , can give a udf for the problem thanks regards ali |
June 3, 2010, 09:17 |
Ibn Hasan
U've just like my prob. maybe U can figure it out through read the tutorial UDF (note: U've the equation, if U familiar to C language (NOT C++) U an do it easily)
Good Luck... |
June 3, 2010, 09:58 |
ali
yes i solved. thanks
one more problem... how to give particle mass flow rate using udf??? any idea.... regards ali |
June 4, 2010, 13:47 |
Compiler ?
Elango
which compiler are you using.i have dev c++ is it advisable to use this to write the udfs or should i be using just c
How can apply mass flow rate boundary condition? | Sima | Phoenics | 1 | December 1, 2007 18:55 |
The reporting of mass flow rate | summer | FLUENT | 1 | July 12, 2007 09:35 |
journal file command for writing mass flow rate | James | FLUENT | 0 | July 26, 2006 10:51 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 17, 2003 19:23 |
