How can I twist a surface with UDF?
Old   July 21, 2010, 11:21
Default How can I twist a surface with UDF? -solved-
Herman
enry is on a distinguished road
I have to twist a surface through mesh-motion. How can I do that? How should I write the UDF? Please help me...
Thanks in advace!
enry is offline   Reply With Quote
Old   July 21, 2010, 16:57
Herman
I solved the problem, with define_grid_motion.
If somebody is interested, here is the UDF.
#include"udf.h"
DEFINE_GRID_MOTION(twist,domain,dt,time,dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(axis);
real delta,xaxis,yaxis,teta,xn,yn,dx,dy,H;
int n;
H = 0.1; /*z-dimension of the model*/
teta = 10*3.14/180; /*rotation angle*/
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
/* update node if the current node has not been previously
visited when looping through previous faces */
if ( NODE_POS_NEED_UPDATE (v))
/* indicate that node position has been update
so that it's not updated more than once */
NODE_POS_UPDATED(v);
xn = cos(teta)*NODE_X(v)-sin(teta)*NODE_Y(v);
yn = sin(teta)*NODE_X(v)+cos(teta)*NODE_Y(v);
dx = xn-NODE_X(v);
dy = yn-NODE_Y(v);
xaxis = dx/sqrt(pow(dx,2) + pow(dy,2));
yaxis = dy/sqrt(pow(dx,2) + pow(dy,2));
NV_D(axis, =, xaxis,yaxis, 0.0);
delta = sqrt(pow(dx,2) + pow(dy,2))*NODE_Z(v)/H;
NV_V_VS(NODE_COORD(v), =, NODE_COORD(v), +, axis,*,delta);
end_f_loop(f,tf);
Old   September 16, 2010, 13:40
Taher
Taher is on a distinguished road
Hey guys.. I need to move a 2D airfoil through certain angle of attack.. now if I dont want to use CG_Motion.. do you think I can do it through GRID_MOTION.. Like may be threading all the nodes across surface and moving them all..
Taher is offline   Reply With Quote
need help regarding error in surface rxn UDF Ashish Jain FLUENT 0 May 16, 2005 10:43
need help regarding surface reaction UDF Ashish Jain FLUENT 0 May 11, 2005 14:31
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
