Heat source function of mass flow
Old   September 16, 2010, 13:16
Default Heat source function of mass flow
MarcVi is on a distinguished road
I am using an energy source to model a combustion. Unfortunately, in Fluent if I used a constant value as heat source, the area (in the region of heat source) with strong flow are colder than the one with steady flow. In reality, the more gas is flowing, the merrier it burns. So I try to write an udf saying that source is proportional to velocity magnitude, but the results where not that good. Has any one a better idea? Thank you
MarcVi is offline   Reply With Quote
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
