Can I use UDF function to solve this problem?
Old   December 10, 2010, 02:24
Default Can I use UDF function to solve this problem?
zhuliang
bright181 is on a distinguished road
I want to simulate the process of the methane flow into a dynamic mesh. I hope the methane flows into the cylinder of dynamic mesh when the mesh has moved for a few seconds(the deformation of cylinder can form turbulence), that means I have to control the timing and duration of methane flow. Can I use UDF to define a inlet boundry to do this thing?
Thank you in advance
bright181 is offline   Reply With Quote
Old   December 10, 2010, 03:51
Bernhard
Bernhard is on a distinguished road
Yes, I suppose a DEFINE_PROFILE will do.
Bernhard is offline   Reply With Quote
Old   December 10, 2010, 04:23
zhuliang
You means I have to define a periodic pressure profile in udf?
Old   December 10, 2010, 04:46
Bernhard
I don't know your precise set-up (concentration, two-fluid or?), but in general you can control your boundary condition in time and space using a DEFINE_PROFILE UDF. You can check the UDF Manual for some examples.
Parallel UDF problem Lindsay FLUENT 4 June 20, 2016 09:37
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 07:51
problem in compoile UDF h.daniyel FLUENT 5 June 12, 2008 05:06
C_NNODES UDF 'function' problem Matthew Brannock FLUENT 2 June 21, 2000 22:46
